73 | | * r.import: use auto-adjustment for lat/lon |
74 | | * r.in.gdal: fix column offset and column mapping when limiting import to the current region |
75 | | * v.db.dropcolumn: preserve field length for field type CHARACTER |
76 | | * r.cross: create categories for output value 0, it is a valid result |
77 | | * r.texture: Fatal error if one of the requested output maps exists |
78 | | * v.random restrict wrong categories assigned, see #3524 |
79 | | * t.rast.series: Fixed bug #3223 wrong time stamp for raster map in case where condition was used |
80 | | * i.ortho.transform: do not overwrite transformed coordinates |
81 | | * t.info: activate -h flag |
82 | | * r.in.gdal: print only proj comparision when -j flag is given (r.in.gdal -j is mostly used in scripts) |
83 | | * v.in.ogr: fix duplicate column names |
| 73 | * G74:r.import: use auto-adjustment for lat/lon |
| 74 | * G74:r.in.gdal: fix column offset and column mapping when limiting import to the current region |
| 75 | * G74:v.db.dropcolumn: preserve field length for field type CHARACTER |
| 76 | * G74:r.cross: create categories for output value 0, it is a valid result |
| 77 | * G74:r.texture: Fatal error if one of the requested output maps exists |
| 78 | * G74:v.random restrict wrong categories assigned, see #3524 |
| 79 | * G74:t.rast.series: Fixed bug #3223 wrong time stamp for raster map in case where condition was used |
| 80 | * G74:i.ortho.transform: do not overwrite transformed coordinates |
| 81 | * G74:t.info: activate -h flag |
| 82 | * G74:r.in.gdal: print only proj comparision when -j flag is given (r.in.gdal -j is mostly used in scripts) |
| 83 | * G74:v.in.ogr: fix duplicate column names |
99 | | * wxGUI: fix problem with Python addons not showing up on Windows, see #3177 |
100 | | * wxGUI: fix d.vect dialog when loading layer without db connection |
101 | | * wxGUI: correctly delete layertree, see #3505 |
102 | | * wxGUI: fix font dialog on mac, #3542 |
| 99 | * G74:wxGUI: fix problem with Python addons not showing up on Windows, see #3177 |
| 100 | * G74:wxGUI: fix d.vect dialog when loading layer without db connection |
| 101 | * G74:wxGUI: correctly delete layertree, see #3505 |
| 102 | * G74:wxGUI: fix font dialog on mac, #3542 |
126 | | * r.stats.zonal manual: added link to r.stats.quantile |
127 | | * i.vi: corrected MSAVI2 equation according |
128 | | * t.register manual: added example to register vector layers (contributed by Ondrej Pesek) and other minor changes/typos |
129 | | * i.atcorr manual: added example to process Sentinel bands (contributed by Zofie Cimburova); general manual clean-up |
130 | | * v.select: make it clear that 'overlap' is 'intersects' in GEOS, not 'overlaps' |
131 | | * t.rast.algebra manual: formatting fixed + See also section added |
| 126 | * G74:r.stats.zonal manual: added link to r.stats.quantile |
| 127 | * G74:i.vi: corrected MSAVI2 equation according |
| 128 | * G74:t.register manual: added example to register vector layers (contributed by Ondrej Pesek) and other minor changes/typos |
| 129 | * G74:i.atcorr manual: added example to process Sentinel bands (contributed by Zofie Cimburova); general manual clean-up |
| 130 | * G74:v.select: make it clear that 'overlap' is 'intersects' in GEOS, not 'overlaps' |
| 131 | * G74:t.rast.algebra manual: formatting fixed + See also section added |
133 | | * t.rast.algebra manual: add NDVI example; use subsections for examples |
134 | | * r.colors manual: decipher 'nv' color |
135 | | * r.series.accumulate manual: update manual explaining accumulation |
136 | | * r.in.wms manual: some WMS examples updated |
| 133 | * G74:t.rast.algebra manual: add NDVI example; use subsections for examples |
| 134 | * G74:r.colors manual: decipher 'nv' color |
| 135 | * G74:r.series.accumulate manual: update manual explaining accumulation |
| 136 | * G74:r.in.wms manual: some WMS examples updated |
