Changes between Version 11 and Version 12 of Release/7.4.0-News
Nov 11, 2017, 10:33:14 AM (7 years ago)
mlennert
  • Release/7.4.0-News
    v11 v12
    3939==== New modules ====
    4040
    41  * G7:r.geomorphon: calculate geomorphons (terrain forms) and associated geometry using machine vision approach (moved from addons)
    42  * G7:g.gui.image2target: managing Ground Control Points for 3D correction.
    43  * G7:g.gui.photo2image: correct scanning distortions of a scanned aerial photo
    44  * G7:v.clip: extract features of input map which overlay features of clip map (moved from addons)
    45  * G7:v.profile: new vector map profiling tool (moved from addons)
     41 * G74:r.geomorphon: calculate geomorphons (terrain forms) and associated geometry using machine vision approach (moved from addons)
     42 * G74:g.gui.image2target: managing Ground Control Points for 3D correction.
     43 * G74:g.gui.photo2image: correct scanning distortions of a scanned aerial photo
     44 * G74:v.clip: extract features of input map which overlay features of clip map (moved from addons)
     45 * G74:v.profile: new vector map profiling tool (moved from addons)
    4646
    4747
    4848==== Major module changes ====
    4949
    50  * G7:g.proj: When a new location is created from vector data, use the default region s=0 n=1 w=0 e=1 res=1 to avoid potentially invalid region settings (r71491)
     50 * G74:g.proj: When a new location is created from vector data, use the default region s=0 n=1 w=0 e=1 res=1 to avoid potentially invalid region settings (r71491)
    5151 * fixed longitude wrapping for lat/lon locations
    5252 * support import of raster maps exceeding 90N or 90S or with an EW extent larger than 360 degrees
    5353 * lat/lon: automatically fix floating point precision errors in the grid geometry of imported raster maps created with GIS software that uses limited floating point precision (common problem).
    54  * G7:r.out.gdal: now creates overviews to enhance compatibility with other GIS software packages
    55  * G7:r.regression.multi: added RMSE and MAE estimation
    56  * G7:r.what: added new -v flag to return also vector category
    57  * G7:r3.null: unit tests added
    58  * G7:v.vect.stats: New cat and where options for area and point vector maps to perform counts or estimate statistics only with selected points over selected areas (r71543)
    59  * G7:v.out.ogr: New -l flag to list supported formats (r71552)
    60  * G7:v.out.ogr: Default format changed from Esri Shapefile to OGC GeoPackage (#3428)
    61  * G7:v.net.alloc and G7:v.net.iso: added flag for unique and original categories (#517)
    62  * G7:v.edit: tool=merge has an improved iteration over list of lines, improved skip invalid lines and zero length lines; added Vedit_extend_lines, improved intersection check; better handling of Vedit_connect_lines by extending both lines; fixed snapping to background map.
    63  * G7:v.external: new where option
    64  * G7:i.segment: new mean shift algorithm
    65  * G7:i.atcorr: added support for Pleiades1a, Pleiades1b, Spot6, Spot7, Sentinel-2A, Rapideye, Worldview3
    66  * G7:i.modis.qc: Added mod09GA QA definitions
     54 * G74:r.out.gdal: now creates overviews to enhance compatibility with other GIS software packages
     55 * G74:r.regression.multi: added RMSE and MAE estimation
     56 * G74:r.what: added new -v flag to return also vector category
     57 * G74:r3.null: unit tests added
     58 * G74:v.vect.stats: New cat and where options for area and point vector maps to perform counts or estimate statistics only with selected points over selected areas (r71543)
     59 * G74:v.out.ogr: New -l flag to list supported formats (r71552)
     60 * G74:v.out.ogr: Default format changed from Esri Shapefile to OGC GeoPackage (#3428)
     61 * G74:v.net.alloc and G74:v.net.iso: added flag for unique and original categories (#517)
     62 * G74:v.edit: tool=merge has an improved iteration over list of lines, improved skip invalid lines and zero length lines; added Vedit_extend_lines, improved intersection check; better handling of Vedit_connect_lines by extending both lines; fixed snapping to background map.
     63 * G74:v.external: new where option
     64 * G74:i.segment: new mean shift algorithm
     65 * G74:i.atcorr: added support for Pleiades1a, Pleiades1b, Spot6, Spot7, Sentinel-2A, Rapideye, Worldview3
     66 * G74:i.modis.qc: Added mod09GA QA definitions
    6767
    6868
    7070==== Minor module changes ====
    7171
    72  * G7:r.clump: fuzzy clumping, multispectral clumping, minimum clump size
    73  * G7:r.sim.water: added parallelization support
    74  * G7:r.sim.sediment: added parallelization support
    75  * G7:r.in.lidar: added -d flag to use base raster resolution instead of computational region
    76  * G7:r.in.gdal: new -r flag to optionally limit import to the current region
    77  * G7:r.import: added support to subset to region boundaries when importing (extent=region)
    78  * G7:r.mapcalc: implemented computational region settings based on disjoint union and intersection computation from all input raster maps in an expression
    79  * G7:r.mapcalc: added area() function to calculate area of pixels
    80  * G7:r.mapcalc: introduced new functions to access current region dimensions in number of cells
    81  * G7:r.reclass: it is possible to use more than 100 rules now
    82  * G7:r.resamp.stats: range, count and diversity methods introduced
    83  * G7:v.in.ogr: Fix import of OSM data (r71464)
    84  * G7:v.in.ogr: When a new location is created, use the default region s=0 n=1 w=0 e=1 res=1 to avoid potentially invalid region settings (r71490)
    85  * G7:v.in.ogr: Support new curve geometry types starting with GDAL 2.0 (r71508, r71514)
    86  * G7:v.in.ogr: code restructuring (r71550)
     72 * G74:r.clump: fuzzy clumping, multispectral clumping, minimum clump size
     73 * G74:r.sim.water: added parallelization support
     74 * G74:r.sim.sediment: added parallelization support
     75 * G74:r.in.lidar: added -d flag to use base raster resolution instead of computational region
     76 * G74:r.in.gdal: new -r flag to optionally limit import to the current region
     77 * G74:r.import: added support to subset to region boundaries when importing (extent=region)
     78 * G74:r.mapcalc: implemented computational region settings based on disjoint union and intersection computation from all input raster maps in an expression
     79 * G74:r.mapcalc: added area() function to calculate area of pixels
     80 * G74:r.mapcalc: introduced new functions to access current region dimensions in number of cells
     81 * G74:r.reclass: it is possible to use more than 100 rules now
     82 * G74:r.resamp.stats: range, count and diversity methods introduced
     83 * G74:v.in.ogr: Fix import of OSM data (r71464)
     84 * G74:v.in.ogr: When a new location is created, use the default region s=0 n=1 w=0 e=1 res=1 to avoid potentially invalid region settings (r71490)
     85 * G74:v.in.ogr: Support new curve geometry types starting with GDAL 2.0 (r71508, r71514)
     86 * G74:v.in.ogr: code restructuring (r71550)
    8787   * projection checks are now performed for all input layers, not only the first layer
    8888   * projection checks are a bit more strict and more verbose in case of trouble
    9292     and to avoid a rare segfault when opening a GRASS database driver
    9393   * the code has been restructured to make it a bit less unreadable and to fix the logic of steps (e.g. check output only if output is created)
    94  * G7:v.rast.stats: added new -d flag for line densification (as in G7:v.to.rast) and corresponding tests
    95  * G7:v.what: new -m flag to query overlapping features
    96  * G7:v.patch: build topology after appending
    97  * G7:v.surf.rst: new parallel implementation and testsuite
    98  * G7:t.rast.series: added quantile option with test
    99  * G7:t.rast.mapcalc: added warning before removing empty (null) maps
    100  * G7:t.rast.export: added GDAL options to support GeoTiff compression
    101  * G7:t.info: Add test to verify the support of non ascii code
    102  * G7:t.rast.what:
    103    * Fixed null value bug, null value definitions are now passed to G7:r.what correctly
     94 * G74:v.rast.stats: added new -d flag for line densification (as in G74:v.to.rast) and corresponding tests
     95 * G74:v.what: new -m flag to query overlapping features
     96 * G74:v.patch: build topology after appending
     97 * G74:v.surf.rst: new parallel implementation and testsuite
     98 * G74:t.rast.series: added quantile option with test
     99 * G74:t.rast.mapcalc: added warning before removing empty (null) maps
     100 * G74:t.rast.export: added GDAL options to support GeoTiff compression
     101 * G74:t.info: Add test to verify the support of non ascii code
     102 * G74:t.rast.what:
     103   * Fixed null value bug, null value definitions are now passed to G74:r.what correctly
    104104   * added function to convert granularity to a smaller granularity
    105105
    117117 * Simple Python Editor is now available from the File menu.
    118118 * Font can be selected interactively in module dialogs and there are some new symbols for vectors.
    119  * G7:g.gui.gcp: vector map rectification has been improved (#3066)
     119 * G74:g.gui.gcp: vector map rectification has been improved (#3066)
    120120
    121121
