Changes between Version 15 and Version 16 of Release/7.2.2-News
- Aug 31, 2017, 2:10:49 PM (7 years ago)
Release/7.2.2-News
v15 v16 42 42 A series of stability fixes, manual improvements and a few language translations have been added. 43 43 44 The GRASS GIS 7.2.2 release provides '''more than 80 fixes and improvements''' with respect to GRASS GIS 7.2.1.44 The GRASS GIS 7.2.2 release provides '''more than 100 fixes and improvements''' with respect to GRASS GIS 7.2.1. 45 45 46 46 ==== New modules ==== … … 51 51 52 52 * G72:r.unpack and G72:v.unpack: new flag (-p) added to print projection info and exit 53 * G72:temporal lib: use str not unicode and encode variables resulting from gisenv() 54 * G72:v.lidar.growing: fix wrong usage of Rast_easting_to_col() 53 55 54 56 ==== Minor module changes ==== … … 63 65 * G72:v.in.ogr: disable OGR dsn corruption 64 66 * G72:v.in.ogr GUI generates invalid layer parameter 67 * G72:v.in.ogr: account for empty fields even if the field is set (since GDAL 2.2 65 68 * G72:v.kernel: fix using mask 66 69 * G72:v.lidar.edgedetection+v.lidar.correction: output options not required if -e flag is given 67 * G72:v. lidar.growing: fix wrong usage of Rast_easting_to_col()70 * G72:v.out.ogr: preserve previous attribute export with GDAL 2.2+ 68 71 * G72:v.out.postgis: do not print build info when exporting simple features 69 70 72 71 73 ==== GUI changes ==== … … 79 81 * wxGUI: remove decorations when creating new workspace 80 82 * wxGUI: fix rendering in latlon when resolution is high 83 * wxGUI: gui_core: fix labels to avoid high CPU usage 81 84 82 85 ==== PyGRASS changes ==== 83 86 84 * python ctypesgencore: lexer support added for FLT64X_EPSILON (fixes GCC7 issues) 87 * Python ctypesgencore: lexer support added for FLT64X_EPSILON (fixes GCC7 issues) 88 * Python ctypes: removed builtins import in python2 85 89 86 90 ==== Library changes ==== … … 102 106 ==== Docker support ==== 103 107 104 * a Dockerfile has been added in order to easily generate a docker image which includes GRASS GIS 7.2 108 * a Dockerfile has been added in order to easily generate a docker image which includes GRASS GIS 7.2, available from https://hub.docker.com/r/neteler/grassgis7/ 109 105 110 ===== MS Windows ===== 106 111 … … 109 114 ==== Manual pages ==== 110 115 116 * G72:db.select: update man page to indicate that SQL statements have to be one complete query per line 117 * G72:m.proj: correct example for Long/Lat WGS84 output in decimal degree 111 118 * G72:r.stats.quantile and r.stats.zonal manuals: examples added 112 119 * G72:v.clean: add example which shows errors visually 113 120 * G72:v.generalize manual: screenshots added 121 * G72:v.in.ogr: update manual (cnames->columns) 122 * G72:v.in.ogr: comment out db.connect/db.login approach to PostGIS import and add info on schema usage 114 123 * G72:v.random manual: example added for generating random points in selected polygons 115 124 * G72:v.univar/G72:v.db.univar: update of manual to clarify difference
