Changes between Version 22 and Version 23 of Release/7.0.5-News
- Sep 18, 2016, 2:34:37 PM (8 years ago)
Release/7.0.5-News
v22 v23 54 54 ==== Minor module changes ==== 55 55 56 * G70:d.barscale/northarrow: fix layout when using frame, see #3121 57 * G70:d.histogram: fix x axis labels for small numbers, see #2463 58 * G70:d.mon: enlarge width to unhide selection window; solves Gtk-CRITICAL GtkCheckButton message flooding (#3117) 59 * G70:d.northarrow: fix multiplication of arrow in latlon regions, see #1242 and #1410 60 * G70:d.wms: fix move temp file with os.rename (fix #3148) 61 * G70:db.login: PostgreSQL DB driver "pg": fix connection debug message to include also login info 62 * G70:g.extension: fix loading of temporal addons 56 63 * G70:g.region: fix uninitialized struct - fixes convergence angle, #1500 57 * G70: d.northarrow: fix multiplication of arrow in latlon regions, see #1242 and #141064 * G70:i.segment: fix manhattan distance 58 65 * i.eb.* + i.evapo.*: fix for !MegaJoules per meter square per day 59 * G70:i.segment: fix manhattan distance 60 * G70:i.vi: writing of color table fixed 66 * G70:i.vi: print msg which index is actually calculated; fix ARVI name; apply standard NDVI color table in case of viname=ndvi; writing of color tables fixed 61 67 * G70:r.mapcalc: fix wrong result when neighborhood modifier takes a cell above first 62 * G70:v.category: fix Windows bug63 * G70:i.vi: print msg which index is actually calculated; fix ARVI name; apply standard NDVI color table in case of viname=ndvi64 * G70:d.barscale/northarrow: fix layout when using frame, see #312165 68 * G70:r.out.gdal: enhance compatibility WRT metadata 66 * G70:d.histogram: fix x axis labels for small numbers, see #246367 * G70:v.in.ogr Segmentation fault (fix #2868)68 69 * G70:r.to.vect: delete output on error (see #2394) 69 * G70:v.in.ogr key flag does not change category values and you loose connection between features and attributes (fix #1494) 70 70 * G70:v.category: fix copy categories; fix Windows bug 71 * G70:v.in.ogr key flag does not change category values and you loose connection between features and attributes (fix #1494);fix segmentation fault (fix #2868) 72 * G70:v.what: escape backslash in attributes for valid JSON, see #3133 73 * G70:wxGUI: escape ampersand when writing d.wms into workspace, see #3147 71 74 ==== GUI changes ==== 72 75
