Changes between Version 7 and Version 8 of HowToMaintainGrassWorkflowUsingGit
- 09/22/11 12:13:42 (14 years ago)
TabularUnified HowToMaintainGrassWorkflowUsingGit
v7 v8 15 15 It is also possible to copy complete repository, including trunk, branches and tags modules. Learn about `--stdlayout` option dedicated for this purpose. However, note that this initial fetch is a time consuming process (fetching of SVN trunk takes nearly two hours). 16 16 17 Next, fetch complete copy of G DALtrunk:17 Next, fetch complete copy of GRASS trunk: 18 18 19 19 {{{ … … 23 23 The file ''grass-git-authors.txt'' (attached) is used by Git to translate names of SVN committers to Git names which uses format "Full name <e-mail>". Specifying the `--authors-file` option is optional, but recommended. 24 24 25 It may be a good idea to compress Git repository in order to save some space. For example, SVN trunk occupies nearly 140 MB of disk space. Git can compress it to about 100 MB. Git provides a dedicated command for this purpose [http://www.kernel.org/pub//software/scm/git-core/docs/git-gc.html git-gc]:25 It may be a good idea to compress Git repository in order to save some space. For example, SVN trunk occupies nearly 230 MB of disk space. Git can compress it to about 90 MB. Git provides a dedicated command for this purpose [http://www.kernel.org/pub//software/scm/git-core/docs/git-gc.html git-gc]: 26 26 27 27 {{{
