Changes between Version 87 and Version 88 of HowToGit
Apr 8, 2020, 5:53:31 AM (4 years ago)
wenzeslaus
Add warnings, details and fork to the Made a mess
  • HowToGit
    v87 v88
    287287
    288288This last steps will fail if somebody else did backport after you did the rebase step above. If that's the case, just update your local branch again with the same //git rebase// command as before.
    289 === Made a mess? Fix it ===
    290
    291 Example: mess happened on releasebranch_7_8:
    292
    293 {{{
    294 git reset --hard upstream/releasebranch_7_8
    295 git pull upstream releasebranch_7_8 --rebase
    296
    297 # now all should be clean again
    298 }}}
    299
     289=== Made a mess? ===
     290
     291If you made a mess in the upstream repo (the OSGeo repo) or you think you did, consult on grass-dev mailing list.
     292
     293If you have something you don't like in your local branch or in the branch in your fork, you can trash any changes you made and replace your branch with whatever is in the upstream repo.
     294
     295Make sure you don't have any local changes or changes on the branch in your fork because this will wipe them out.
     296
     297Make sure your remotes are set right (see above, origin to your fork and upstream to OSGeo repo):
     298
     299{{{
     300git remote -v
     301}}}
     302
     303Make sure you are on the right branch (here using releasebranch_7_8):
     304
     305{{{
     306git checkout releasebranch_7_8
     307}}}
     308
     309Bring the local branch to the state of the upstream branch trashing all local changes:
     310
     311{{{
     312git reset --hard upstream/releasebranch_7_8
     313}}}
     314
     315Update the local repo from the upstream:
     316
     317{{{
     318git fetch --all --prune
     319git rebase upstream/releasebranch_7_8
     320}}}
     321
     322If you want to keep the branch in your fork up to date, you may need to also overwrite anything which is on that branch there. Be sure you are force pushing only to origin and that origin is your fork. Force push the state of the local branch into your fork:
     323
     324{{{
     325git push --force origin releasebranch_7_8
     326}}}
    300327== Code review: generate a single diff for a PR with multiple commits ==
    301328
