Changes between Version 15 and Version 16 of HowToBackport
- Apr 14, 2013, 3:55:19 AM (11 years ago)
HowToBackport
v15 v16 29 29 30 30 To use them, first make sure all branches are up to date (`svn up`) and clean (`svn diff`), 31 then `cd` into the topof the source tree you want to ''pull '''in''' to''. If you try to run it from the module's own subdir it will fail.31 then `cd` into the '''top''' of the source tree you want to ''pull '''in''' to''. If you try to run it from the module's own subdir it will fail. 32 32 Then run the script named for the branch you want to pull ''from'', followed by the revision number of the change you wish to merge (no leading "r" or [square brackets] around the rev number please). Mind that you might want to run '`svn propdel svn:mergeinfo .`' before doing an untargeted 'svn commit'. 33 33 34 Example: 35 {{{ 36 # make the original edit 37 cd devbr6 38 svn diff lib/gis/parser.c 39 svn up lib/gis/parser.c 40 vi lib/gis/parser.c 41 svn diff lib/gis/parser.c 42 # .. run make; test the change .. 43 svn commit lib/gis/parser.c # note the rev number of the commit 44 45 # now backport it 46 cd ../relbr64 47 svn diff lib/gis/parser.c 48 svn up lib/gis/parser.c 49 svn65merge 54321 50 svn diff lib/gis/parser.c 51 # .. run make; test the change .. 52 svn commit lib/gis/parser.c 53 }}} 34 54 == Comparing branches == 35 55
