Changes between Version 53 and Version 54 of Grass8Planning
05/29/20 13:29:12 (5 years ago)
hellik
  • Grass8Planning
    v53 v54
    2626  * GRASS Python packages, C libraries and includes should install into standard paths thus being readily available for import (Python), execution (C), or includes.
    2727  * On Linux/unix, make install and distributions need to be changed.
    28   * On Mac and Win, if you care about the above, you probably want to use Anaconda (or WSL) anyway, so this is how it should be distributed. Standalone and OSGeo4W installers should do the closest reasonable thing.
     28  * On Mac and Win, if you care about the above, you probably want to use Anaconda (or WSL) anyway, so this is how it should be distributed. Standalone and OSGeo4W installers should do the closest reasonable thing. (adding C libraries and Python packages in system paths isn't a good idea in windows; it has to be avoided to pollute system path)
    2929 * Additions:
    3030  * Documented and short full initialization procedures for Python and C
