Changes between Version 69 and Version 70 of Grass7Planning
- Jan 10, 2015, 2:48:03 AM (10 years ago)
Grass7Planning
v69 v70 18 18 * Update [wiki:Release/7.0.0RC1-News] 19 19 20 To be backported:21 * ~~r.distance: r60566, r60565, r60564, r60563, r60497~~22 * ~~g.rename: r60976~~23 * ~~manage/lister: r62085~~24 25 20 Relevant differences - to be clarified: 26 21 * lib/db/dbmi_base/connect.c 27 * ~~lib/driver/text3.c (martinl) r63461~~28 22 * lib/gis/strings.c G_chop() (Markus Metz) r63308 29 23 * Change handling of display frame, graphical clip window (Glynn) (r62026 + r62036) 30 24 * lib/python/script/core.py (martinl) r63528 31 25 * db.connect substitute variables for database name (-cpd) (martinl) r59671 32 * r.proj bugfixes (Markus Metz) r6369733 26 * r.spread (Vaclav) r63777 34 * new r3 modules by Anna (perhaps yet experimental)35 27 * checks for Vect_open_* return value to avoid potential segmentation fault: r60054 <<-- wasn't the idea to avoid these ugly tests in G7? 36 * lib/vector/Vlib/ascii.c (Markus Metz) r63599, r6359637 * lib/vector/Vlib/build.c (Markus Metz) r6149238 * lib/vector/Vlib/line.c (Markus Metz) r6197839 * lib/vector/Vlib/snap.c (Markus Metz) r63601, r63645, r6391840 * lib/vector/Vlib/write_nat.c (Markus Metz) r6340441 * lib/vector/Vlib/remove_areas.c (Markus Metz) r6149142 43 To be removed:44 * ~~v.in.sites~~45 * ~~old_vector and v.convert (MartinL) r63930, r63931~~46 28 47 29 Source code changes:
