Changes between Version 324 and Version 325 of Grass7Planning
- Jan 18, 2017, 7:58:00 AM (8 years ago)
Grass7Planning
v324 v325 45 45 * i.atcorr: Sentinel-2A r70161 (Test feedback in ML needed first) 46 46 47 * ~~r.compress: add shell-style output, add info about NULL file compression: r70337.~~ Done in r7039148 * ~~r.what: print labels also for FCELL/DCELL maps: r69356.~~ Done in r7019649 47 * r.grow.distance: clean up after r68611: r69327 50 48 * r.in.lidar: Storage type 51 49 * r.in.xyz: unify keywords and method descriptions with r.in.lidar (r68596): r68600 52 * ~~r.null: fix recreate and remove NULL file: r70338.~~ Done in r70390.53 * ~~r.quantile: fix memory violations: r69774.~~ Done in r70392.54 * r.stats.quantile: fix memory violations, optimize for a large number of base categories: r6977655 50 56 51 * v.in.lidar: check for valid LAS reader as in r.in.lidar r68982 + r70134 57 52 * vector modules: Added layer specific database information to v.info extended metadata flag: r69535 58 53 * v.vol.rst: improve wording of warning (#3100): r69439 59 * ~~v.to.rast: fix category labels for use=attr: r69357.~~ Done in r7039360 * ~~v.to.rast: just leave the color table to be the default: r69326.~~ Done in r7039361 54 * v.what.strds: add capabilities to use names also for temporal dataset with minutes and seconds granularity: r69331 62 55
