Changes between Version 286 and Version 287 of Grass7Planning
- Dec 11, 2016, 12:00:00 PM (8 years ago)
Grass7Planning
v286 v287 39 39 === 7.2.1 (to be backported) === 40 40 41 * what about the lib/proj/ update concerning the .lla files etc? 41 * libproj: cleanup of local copies of NAD and datum shift files which are used from GDAL; extended documentation in README.txt (trac #2456): r69211 42 * libproj: Fix GPJget_datum_params() to respect r69211 (see #2456): r69494 42 43 * libgis: set valid ZLIB compression level: r69388 44 * lib/python/temporal: major differences 43 45 * parser: add standard option for 2D raster map type: r68867 44 46 * use cats title as primary, see #3035 (r68746, r68747, r68748, r69645) … … 57 59 * r.stats.quantile: fix memory violations, optimize for a large number of base categories: r69776 58 60 * r.texture fixes? 59 61 60 62 * v.in.ascii: add text=none to restore geonames import: r69354 61 63 * v.in.lidar: check for valid LAS reader as in r.in.lidar r68982
