Changes between Version 39 and Version 40 of Grass7/VectorLib/PostGISInterface
- Jul 21, 2013, 1:08:46 AM (11 years ago)
v39 v40 25 25 By default data are read/write as simple features. If ''PostGIS Topology schema'' is defined then the data provider reads/writes topological elements from provided schema. 26 26 27 Note that [wiki:Grass7/VectorLib/OGRInterface#DirectOGRreadaccess direct access] like forGRASS-OGR data provider is not currently implemented. In other words to access PostGIS data (using GRASS-PostGIS data provider) is required to create a link using `v.external` command.27 Note that [wiki:Grass7/VectorLib/OGRInterface#DirectOGRreadaccess direct access] similarly GRASS-OGR data provider is not currently implemented. In other words to access PostGIS data (using GRASS-PostGIS data provider) is required to create a link using `v.external` command. 28 28 == Simple features access == 29 29
