Changes between Version 22 and Version 23 of Grass7/VectorLib/PostGISInterface
- Nov 27, 2012, 8:50:17 AM (11 years ago)
v22 v23 24 24 By default data are read/write as simple features. If ''PostGIS Topology schema'' is defined then the data provider reads/writes topological elements from provided schema. 25 25 26 Note that [wiki:Grass7/VectorLib/OGRInterface#DirectOGRreadaccess direct access] like for GRASS-OGR data provider is not currently implemented. In other words to access PostGIS data is required to create a link using `v.external` command.26 Note that [wiki:Grass7/VectorLib/OGRInterface#DirectOGRreadaccess direct access] like for GRASS-OGR data provider is not currently implemented. In other words to access PostGIS data (using GRASS-PostGIS data provider) is required to create a link using `v.external` command. 27 27 == Simple features access == 28 28
