Changes between Version 25 and Version 26 of Grass7/TemporalGISAlgebra
- Oct 20, 2014, 12:46:20 PM (10 years ago)
v25 v26 167 167 This is very important, so we do not need to specify a global time reference (a space time dataset) for temporal processing. 168 168 169 ==== Single map with temporal extent ==== 170 171 The temporal algebra can also handle single maps with time stamps in the tmap function. 172 tmap() 173 For example: 174 {{{ 175 C = A {:,during} tmap(event) 176 }}} 177 This statement select all maps from space time data set A that are during the temporal extent of single map 'event' 178 169 179 == Temporal Vector Algebra == 170 180 … … 218 228 temporal operators and arithmetic operators. 219 229 230 ==== Arithmetic operators ==== 231 {{{ 232 Symbol Description 233 234 + Addition 235 - Substraction 236 * Multiplication 237 / Division 238 % Modulus 239 }}} 240 241 ==== Arithmetic function ==== 242 {{{ 243 Symbol 244 245 exp 246 log 247 sqrt 248 abs 249 cos 250 acos 251 sin 252 asin 253 tan 254 double 255 float 256 int 257 isnull 258 isntnull 259 null 260 exist 261 }}} 262 220 263 Examples: 221 264 Create the sum of all maps from STRDS A and B that have equal time stamps and store the new maps in STRDS C: … … 254 297 }}} 255 298 256 All supported operators and functions are documented below. 257 299 300 ==== Single raster map function ==== 301 302 The temporal raster algebra feature also a function to integrate single raster maps without time stamps into the expressions. 303 map() 304 For example: 305 {{{ 306 C = A * map(constant_value) 307 }}} 308 This statement multiply all raster maps from space time raster data set A with the raster map 'constant_value' 258 309 259 310 = Overview of all supported spatio-temporal operators and functions =
