Changes between Version 95 and Version 96 of Grass7/NewFeatures
- Aug 28, 2012, 6:01:10 AM (12 years ago)
Grass7/NewFeatures
v95 v96 172 172 == Renamed options == 173 173 174 Some parameter names (options) have been renamed to achieve greater consistency. User scripts from GRASS 6 may need minor updates to run with GRASS 7 according to the changes listed below: 175 176 Display module changes: 177 * d.correlate 178 * layers -> map 179 * d.erase 180 * color -> bgcolor 181 * background -> bgcolor 174 182 * d.rast 175 183 * catlist and vallist options merged into new values option 176 184 * overlay flag inverted to new opaque flag 177 * r.fill.dir 178 * input -> elevation 179 * elevation -> depressionless 185 * d.rast.leg 186 * rast -> raster 187 * d.vect 188 * wcolumn -> width_column 189 * wscale -> width_scale 190 * rot_column -> rotation_column 191 192 Database management module changes: 193 * db.out.ogr 194 * db_table -> table 195 196 General map management module changes: 197 * g.mlist 198 * sep -> fs 199 * g.mapsets 200 * addmapset,removemapset -> operation 201 * measure -> method 202 * g.pnmcomp 203 * background -> bgcolor 204 * g.region 205 * n -> north 206 * s -> south 207 * e -> east 208 * w -> west 209 * t -> top 210 * b -> bottom 211 212 Image processing module changes: 213 * i.atcorr 214 * iimg -> input 215 * iscl -> range 216 * ialt -> elevation 217 * ivis -> visibility 218 * icnd -> parameters 219 * oimg -> output 220 * oscl -> rescale 221 * input -> map 222 * input -> map 223 * i.fusion.brovey 224 * outputprefix -> output_prefix 225 * i.image.mosaic 226 * images -> input 227 * i.in.spotvgt 228 * file -> input 229 * rast -> output 230 * i.in.gns 231 * file -> input 232 * vect -> output 233 * i.spectral 234 * raster -> input 235 * coord -> east_north 236 * i.tasscap 237 * outprefix -> output_prefix 238 239 Raster module changes: 180 240 * r.basins.fill 181 241 * c_map -> cnetwork 182 242 * t_map -> tnetwork 183 243 * result -> output 244 * r.blend 245 * output -> output_prefix 246 * r.colors.stddev 247 * input -> map 248 * r.fill.dir 249 * input -> elevation 250 * elevation -> depressionless 184 251 * r.flow 185 252 * elevin -> elevation … … 193 260 * r.out.tiff 194 261 * -t flag -> -w 262 * r.plane 263 * name -> output 195 264 * r.topmodel 196 265 * belevation -> basin_elevation 197 * r.uslek198 * usle_k -> output199 * r.water.outlet200 * drainage -> input201 * basin -> output202 266 * r.sim.sediment 203 267 * elevin -> elevation … … 218 282 * manin -> man 219 283 * manin_val -> man_value 220 * r.colors.stddev 221 * input -> map 222 * i.atcorr 223 * iimg -> input 224 * iscl -> range 225 * ialt -> elevation 226 * ivis -> visibility 227 * icnd -> parameters 228 * oimg -> output 229 * oscl -> rescale 230 * input -> map 231 * input -> map 284 * r.surf.area 285 * input -> map 286 * input -> map 287 * r.texture 288 * measure -> method 289 * r.to.vect 290 * feature -> type 291 * r.uslek 292 * usle_k -> output 293 * r.water.outlet 294 * drainage -> input 295 * basin -> output 296 * r.what 297 * east_north -> coordinates 298 299 Vector module changes: 300 * v.edit 301 * t -> b 302 * measure -> method 303 * v.in.e00 304 * file -> input 305 * vect -> output 232 306 * v.in.wfs 233 307 * wfs -> url … … 236 310 * colprefix -> column_prefix 237 311 * input -> map 238 * g.region239 * n -> north240 * s -> south241 * e -> east242 * w -> west243 * t -> top244 * b -> bottom245 * g.pnmcomp246 * background -> bgcolor247 * d.erase248 * color -> bgcolor249 * background -> bgcolor250 * i.spectral251 * raster -> input252 * coord -> east_north253 * i.fusion.brovey254 * outputprefix -> output_prefix255 * i.image.mosaic256 * images -> input257 * r.blend258 * output -> output_prefix259 312 * v.what.vect 260 313 * vector -> map 261 314 * qvector -> qmap 262 * r.plane263 * name -> output264 * v.rast.stats265 * vector -> map266 * d.rast.leg267 * rast -> raster268 * d.correlate269 * layers -> map270 * i.tasscap271 * outprefix -> output_prefix272 * i.in.spotvgt273 * file -> input274 * rast -> output275 * i.in.gns276 * file -> input277 * vect -> output278 * db.out.ogr279 * db_table -> table280 * v.in.e00281 * file -> input282 * vect -> output283 * d.vect284 * wcolumn -> width_column285 * wscale -> width_scale286 * rot_column -> rotation_column287 * r.to.vect288 * feature -> type289 * r.surf.area290 * input -> map291 * input -> map292 * r.texture293 * measure -> method294 * v.edit295 * t -> b296 * measure -> method297 * g.mapsets298 * addmapset,removemapset -> operation299 * measure -> method300 * r.what301 * east_north -> coordinates
