Changes between Version 343 and Version 344 of Grass7/NewFeatures
- Nov 26, 2014, 3:36:39 PM (10 years ago)
Grass7/NewFeatures
v343 v344 359 359 * dt= -> dtime 360 360 * dsn= -> input 361 361 362 === Display module changes === 363 362 364 * G7:d.barscale 363 365 * background_color -> bgcolor 366 * G7: d.colorlist 367 * fs -> separator 364 368 * G7:d.correlate 365 369 * layers -> map … … 419 423 * G7:d.rast.num 420 424 * dp -> precision 425 421 426 === Database management module changes === 422 427 … … 450 455 * G7:g.mapset 451 456 * gisdbase -> dbase 457 452 458 === Image processing module changes === 453 459 … … 461 467 * oscl -> rescale 462 468 * input -> map 469 * G7:i.biomass 470 * lightuseefficiency -> lightuse_efficiency 471 * transmissivitysingleway -> transmissivity_singleway 472 * wateravailability -> water_availability 473 * G7:i.evapo.mh 474 * averagetemperature -> average_temperature 475 * maximumtemperature -> maximum_temperature 476 * minimumtemperature -> minimum_temperature 477 * netradiationdiurnal -> netradiation_diurnal 478 * G7:i.evapo.pt 479 * airtemperature -> air_temperature 480 * atmosphericpressure -> atmospheric_pressure 481 * netradiation -> net_radiation 482 * soilheatflux -> soil_heatflux 483 * priestley_taylor_coef -> priestley_taylor_coef 463 484 * G7:i.image.mosaic 464 485 * images -> input … … 516 537 * chan5 -> band5 517 538 * chan7 -> band7 539 518 540 === Raster module changes === 519 541 … … 723 745 * dp -> precision 724 746 * elevscale -> zmultiplier 747 725 748 === Raster 3D module changes === 726 749 … … 740 763 * elevscale -> zmultiplier 741 764 * dp -> precision 765 742 766 === Vector module changes === 743 767 … … 769 793 * G7:v.lrs.where 770 794 * thresh -> threshold 795 * G7:v.mkgrid 796 * coor -> coordinates 771 797 * G7:v.net 772 798 * thresh -> threshold … … 786 812 * sin -> ns_step 787 813 * G7:v.surf.rst 814 * devi -> deviations 788 815 * maskmap -> mask 789 816 * treefile -> treeseg … … 858 885 * G7:v.vol.rst 859 886 * cellinp -> cross_input 887 * devi -> deviations 860 888 * scolumn -> smooth_column 861 889 * wmulti -> wmultiplier … … 872 900 * qlayer -> query_layer 873 901 * qcolumn -> query_column 902 874 903 === Miscellaneous module changes === 875 904 … … 880 909 * G7:m.transform 881 910 * coords -> input 911 882 912 == GRASS GIS 7 Addons == 883 913
