Changes between Version 261 and Version 262 of Grass7/NewFeatures
- Nov 10, 2014, 7:42:18 AM (10 years ago)
Grass7/NewFeatures
v261 v262 113 113 * G7:r.mapcalc: white space is needed before/after the = sign (r.mapcalc "outmap = inmap"); use pthreads for parsing 114 114 * G7:r.neighbours: added new option to process only marked cells (i.e: selective elevation map improvement) 115 * G7:r.pack: Packs up a raster map and support files for copying. 115 * G7:r.pack: Packs up a raster map and support files for copying 116 * G7:r.param.scale: now fast on Windows when there is no data in raster map 116 117 * G7:r.walk: Outputs a raster map showing the anisotropic cumulative cost. Faster by orders of magnitude (10x - 1000x) 117 118 * G7:r.watershed improved from G6.3 to G6.4 to G6.5 to G7: faster, less memory, floating point DEM support, MFD, clean stream extraction from MFD, segmented mode in G7 faster than in G6 by orders of magnitude.
