Changes between Version 37 and Version 38 of Grass7/NewFeatures76
01/20/19 12:06:31 (6 years ago)
veroandreo
typo
  • TabularUnified Grass7/NewFeatures76
    v37 v38
    3535=== Raster modules ===
    3636
    37 This new GRASS GIS release comes with 3 new dedicated raster modules. The first one, G76:r.path, can be used to trace paths from different starting points following input directions, such as the outputs of G76:r.cost, G76:r.walk or G76:r.watershed, among others. The second one, G76:r.buildvrt, provides the very useful functionality of creating virtual raster (VRT) mosaics from a list of input raster maps. This is very useful when the original data are available in tiles which can now be virtually mosaiked to a single map without overhead for easier analysis. G76:r.buildvrt hence allows processing big areas while avoiding the creation of physical maps, especially useful when space is limited.
    38 ​Finally, there is now G76:r.mapcalc.simple, a tool to calculate a new raster map from a simple r.mapcalc expression.
     37This new GRASS GIS release comes with 3 new dedicated raster modules. The first one, G76:r.path, can be used to trace paths from different starting points following input directions, such as the outputs of G76:r.cost, G76:r.walk or G76:r.watershed, among others. The second one, G76:r.buildvrt, provides the very useful functionality of creating virtual raster (VRT) mosaics from a list of input raster maps. This is very useful when the original data are available in tiles which can now be virtually mosaiked to a single map without overhead for easier analysis. G76:r.buildvrt hence allows processing big areas while avoiding the creation of physical maps, especially useful when space is limited. ​Finally, there is now G76:r.mapcalc.simple, a tool to calculate a new raster map from a simple r.mapcalc expression.
    3938
    4039[screenshots here]
