Changes between Version 71 and Version 72 of GitMigration
- May 21, 2019, 2:01:49 PM (5 years ago)
GitMigration
v71 v72 268 268 * Zenodo helpdesk on DOI versioning scheme: ''Zenodo keeps the version number and date in a metadata field that you can change as you see fit even after publishing. By default Zenodo orders the releases in the order we receive them (i.e. by date). This is however only for display purposes, and it is essentially the same way !GitHub orders their releases page. In the metadata however, we do not care about ordering (because it's very hard to model the ordering correctly). We simply have a concept DOI that links to all the the specific version DOIs via !HasVersion/IsVersionOf relationship.'' 269 269 * Zenodo helpdesk on mishaps: ''...in case you make a mistake, we do have the possibility to reorder the releases manually. Naturally we would like to avoid this, however just rest assured that we can fix it if you make a mistake.'' 270 270 * WIP: https://grasswiki.osgeo.org/wiki/GitHub-Zenodo_linkage 271 271 === CI/CD and QA === 272 272 * Travis-CI: https://travis-ci.org/GRASS-GIS/grass-ci
