Changes between Version 3 and Version 4 of GSoC/2021
Feb 2, 2021, 7:21:45 PM (3 years ago)
wenzeslaus
add testing framework
  • GSoC/2021
    v3 v4
    7777* Expected Outcomes:  IPython/Jupyter Notebooks related to grass; some new functions in grass library to show data/tables on IPython/Jupyter Notebooks
    7878* Test of skills: Write a testsuite for a GRASS GIS command, more info [https://grass.osgeo.org/grass72/manuals/libpython/gunittest_testing.html here]
     79
     80=== Integrate testing framework with !GitHub Actions ===
     81
     82* The testing framework was written before migration to !Git/GitHub and when long free runs in 3rd party services were unthinkable. Additionally, different goals overall were prioritized.
     83* An update is needed to reflect that tests are used to evaluate pull requests (PRs).
     84* Most of the updates should be generic enough to integrate well with any CI environment. However, currently GRASS GIS is using !GitHub Actions which open the possibility to make use of specific features there, e.g., upload artifacts for failed tests or do a quick test only of files changed in the PR.
     85* Possibly, use //pytest// (following example of GDAL and Numpy) instead of Python unittest (some parts of grass.gunittest might be replaced by or ported to pytest).
     86* Current tests don't accommodate well tests of the main GRASS executable (which is now more prominent also because `grass ... --exec`).
     87* Both preserving and removing of existing HTML reporting functionality are valid options.
     88
     89* Requirements: Python, !GitHub Actions (YAML configuration)
     90* Mentor: Vaclav Petras
     91* Proposed by: Vaclav Petras
     92* Rating: medium
     93* Expected Outcomes: Effective reporting of test results in pull requests
     94* Test of skills: Fix failing tests and/or write new tests (more is better). Alternatively, addressing a smaller problem in the testing framework is a good task, too.
    7995
    8096=== Improved color management in GRASS GIS ===
