Changes between Version 77 and Version 78 of GSoC/2021/SingleWindowLayout
- Aug 17, 2021, 9:18:08 AM (3 years ago)
v77 v78 480 480 481 481 **Abstract:**\\ 482 This project was focused mainly on the extensive Graphical User Interface refactoring necessary to prepare GRASS for Single-Window GUI. In addition to a good programming base, the simple working Single-Window GUI prototype was built in a parallel environment. This Single-Window frame largely copies the design (mockup) which the author had proposed for the GSoC application (see https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/SingleWindow). All main functionality was put into operation, however, in order to completely replace the current Multi-Window GUI solution, many improvements are expected.482 This project was focused mainly on the extensive Graphical User Interface refactoring necessary to prepare GRASS for Single-Window GUI. In addition to a good programming base, the simple working Single-Window GUI prototype was built in a parallel environment. This Single-Window frame largely copies the design (mockup) which the author had proposed for the GSoC application (see https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/SingleWindow). All main functionality was put into operation, however, in order to completely replace the current Multi-Window GUI solution, many improvements are still expected. 483 483 484 484 **The state of the art BEFORE the start of GSoC:**\\
