Changes between Version 61 and Version 62 of GSoC/2021/SingleWindowLayout
Aug 14, 2021, 10:50:09 AM (3 years ago)
lindakladivova
  • GSoC/2021/SingleWindowLayout
    v61 v62
    455455== Week 10 ==
    456456'''1) What did I complete this week?'''\\
    457 '''2) What am I going to achieve for next week?'''\\
     457
     458First of all, I fixed the size of the automatic notebook which is used for the startup layout. The related PR https://github.com/OSGeo/grass/pull/1775 has still some minor shortcomings with cmd warnings messages but we decided to let it be for now since it would require more intervention in the construction of the map panel status bar widget which is anyway likely to be very simplified or replaced by the settings dialog in the future.
     459
     460Secondly, I implemented the new changing tab event for the center AuiNotebook. You can have a look at PR https://github.com/OSGeo/grass/pull/1780 which is already merged. To provide the fully working GRASS Single-Window GUI prototype, I also opened the PR [https://github.com/OSGeo/grass/pull/1789] which addresses several smaller things related to the AuiNotebook closing event. This PR is not merged yet but I plan to have it done by the end of GSoC. Merging this PR will close the Issue https://github.com/OSGeo/grass/issues/1750 with the new AuiNotebook events.
     461
     462Thirdly, I moved the NewDisplay button to the upper Tools toolbar, see the PR https://github.com/OSGeo/grass/pull/1783 (merged).
     463
     464Lastly, each layer tree is about to have one independent toolbar. I have coded it in the PR https://github.com/OSGeo/grass/pull/1785 which is not in the master branch yet.
     465
     466'''2) What am I going to achieve for next week?'''\\
     467
     468The priorities for the next week are mainly to finish PRs https://github.com/OSGeo/grass/pull/1789 and https://github.com/OSGeo/grass/pull/1785. Unfortunately, we still have not merged the main refactoring PR https://github.com/OSGeo/grass/pull/1675 because it waits for the GRASS 8 release.
     469
     470It probably gets into the GRASS dev version after GSoC.
     471
     472Anyway, I would also like to prepare some startup settings that allow GRASS geeks to try out the GRASS Single-Window prototype. And of course, I am going to finish the final evaluation and sum up my work to the final GSoC report.
     473
     474'''3) Is there any blocking issue?'''\\
     475No, It is not. Please, if you would like to know more info, have a look at my Twitter thread https://twitter.com/GRASSGIS/status/1423254298587275264 where I presented some screenshots of the prepared GUI. :-)
    458476
    459477
