Changes between Version 5 and Version 6 of GSoC/2020/StartupWindow
- May 22, 2020, 8:51:47 AM (4 years ago)
v5 v6 64 64 '''Location wizard - first page''' 65 65 - Major code refactoring 66 - Remove map picture 66 - Remove map picture (see https://github.com/OSGeo/grass/pull/657) 67 67 - Database directory not editable but mentioned 68 68 - Location name marked as required 69 69 - Location title (renamed as description) marked as optional 70 70 - "Set default region and resolution" removed and set automatically if info is available 71 - "Create user mapset" removed (user can do it from the data catalog in the future, now with a button in the startup window) 72 73 74 }}} 75 {{{#!td 76 TBD 71 - "Create user mapset" removed (user can do it from the data catalog in the future, now with a button in the startup window) (see https://github.com/OSGeo/grass/pull/646) 72 73 74 }}} 75 {{{#!td 76 Ok \\ 77 Ok \\ 78 Ok \\ 79 Ok \\ 80 Ok \\ 81 Ok \\ 82 Ok 77 83 }}} 78 84
