Changes between Version 49 and Version 50 of GSoC/2020/StartupWindow
Aug 16, 2020, 3:41:10 AM (4 years ago)
lindakladivova
  • GSoC/2020/StartupWindow
    v49 v50
    660660'''3) Is there any blocking issue?'''\\
    661661No, it is not.
     662
     663
     664== Week 11 ==
     665
     666'''1) What did I complete this week?'''\\
     667I finished implementing the very important PR which distinguishes mapsets by ownership and lock (see https://github.com/OSGeo/grass/issues/714, https://github.com/OSGeo/grass/pull/849). I also fixed a bug which appeared when a user wanted to display a map from a different location. Eventually, it is not allowed and a user needs to switch a mapset first.
     668
     669Currently, there are 3 other PRs that are in the process:
     670
     671* Start in a demo/startup location (see https://github.com/OSGeo/grass/issues/862, https://github.com/OSGeo/grass/pull/868)
     672
     673This issue was a bit broadened. It consists of not only creating a startup location but also a startup mapset. This PR also gives the option to start up whole GRASS GIS without the startup screen.
     674
     675* Check for gislock and other issues when deleting/renaming/editing mapset and location in catalog (see https://github.com/OSGeo/grass/issues/801, https://github.com/OSGeo/grass/pull/904)
     676
     677Almost done, just some smaller cosmetic changes. This PR creates new checking functions that check both mapsets and locations when renaming/deleting.
     678
     679* Switch to another mapset when in use (aka force remove lock) (see https://github.com/OSGeo/grass/pull/906, https://github.com/OSGeo/grass/issues/898)
     680
     681Almost done, this issue offers an option to force the removal of the lock and switch to the mapset anyway.
     682
     683
     684'''2) What am I going to achieve for next week?'''\\
     685
     686I am gonna end up those above-mentioned PRs.
     687Then, I am gonna reflect changes, I made in Data Catalog, in GUI.
     688
     689- Reflect changes done from Data Catalog in GUI and vice versa (see https://github.com/OSGeo/grass/issues/885)
     690 - when map is renamed in data catalog while it is displayed, the layer needs to be changed otherwise rendering fails
     691 - when map is moved elsewhere in data catalog while it is displayed
     692 - new map is created (this item needs to be expanded, there are multiple ways a new map is created)
     693 - current mapset/location is changed from menu
     694 - etc.
     695
     696'''3) Is there any blocking issue?'''\\
     697No, it is not.
