Changes between Version 18 and Version 19 of GSoC/2020/StartupWindow
Jun 12, 2020, 11:27:38 AM (4 years ago)
lindakladivova
  • GSoC/2020/StartupWindow
    v18 v19
    336336
    337337'''1) What did I complete this week?'''\\
     338I focused mainly on completing the PR (see https://github.com/OSGeo/grass/pull/670) regarding the EPSG page. New things that are already incorporated:
     339
     340- remove path to "/usr/share/proj/epsg"
     341- merge search and EPSG code text inputs
     342- searching in a list on the fly
     343- if epsg code is empty, nothing is selected and "next" button is not active
     344- change informative URL according to a query string (link to epsg.io)
     345
     346Other two PRs were established:
     347- Startup GUI automatic detection of grassdata: make case independent (see https://github.com/OSGeo/grass/pull/664, see https://github.com/OSGeo/grass/issues/644). Detects a grassdata directory if present, but it does not detect GRASSDATA, Grassdata, or any other possible combinations of cases. It should be independent to allow for different cultures of case usage in file and directory naming.
     348- Create grassdata automatically on the first GUI startup (see https://github.com/OSGeo/grass/pull/705, see https://github.com/OSGeo/grass/issues/682)
     349After starting GRASS GIS with GUI, the GUI now searches for existing grassdata. If nothing is found, GRASS GIS (GUI) should automatically create directory named grassdata as a subdirectory of a platfrom-dependent directory. This platfrom-dependent directory would be:
     350
     3511. $HOME (os.path.expanduser('~')) on Linux and the like,
     3522. User's Documents on Windows (see dac6d4a for code trying to identify that dir),
     3533. One of the above on macOS - macOS users, please share your ideas.
     3544. If that fails, it should use a temporary directory (/tmp/... etc.) as a fallback.
     355
     356Those PRs are still in progress.
    338357
    339358'''2) What am I going to achieve for next week?'''\\
    340359
     360I would definitely work on finishing PRs see https://github.com/OSGeo/grass/pull/664 and https://github.com/OSGeo/grass/pull/705. Then I will continue in work on Location Wizard particularly Projection page and Final Page. The labels in some pages will be also probably somehow changed, so far it was not addressed.
     361
    341362'''3) Is there any blocking issue?'''\\
    342363
    343
    344
    345
    346
     364No, it isn't.
     365
     366
     367
