Changes between Version 9 and Version 10 of GSoC/2020/StartupWindow
- May 26, 2020, 2:16:27 PM (4 years ago)
v9 v10 294 294 I checked and updated my developer environment so as to be ready to start coding after the bonding period. 295 295 296 '''Four PR already created'''\\ 297 I created two PR related to the First Page of Location Wizard: https://github.com/OSGeo/grass/pull/493 and https://github.com/OSGeo/grass/pull/646. Both of them are already closed. In those PR the layout of this page was changed quite significantly. The database directory was mentioned as the last attribute and can be changed. The Location Name was marked as required. Location Title was renamed as Description and marked as optional (also in the Summary Page this was renamed). Both checkboxes "Set default region and resolution" and "Create user mapset" were removed. 298 299 I also created a single PR related to removing the picture of the world: https://github.com/OSGeo/grass/pull/657 which is still open 300 and made one improvement related to automatic detection of case-independent cases of grassdata directory that is not literally mentioned in the roadmap: https://github.com/OSGeo/grass/pull/664 (issue: https://github.com/OSGeo/grass/issues/644.) 296 301 297 302 (1) https://lists.osgeo.org/pipermail/grass-dev/2018-April/088262.html \\ … … 305 310 306 311 '''1) What did I complete this week?'''\\ 307 I created two PR related to the First Page of Location Wizard. The layout of this page was changed quite significantly. The database directory was mentioned as the last attribute and can be changed. The Location Name was marked as required. Location Title was renamed as Description and marked as optional (also in the Summary Page this was renamed). Both checkboxes "Set default region and resolution" and "Create user mapset" were removed. Also the picture of the world was removed.308 312 309 313 '''2) What am I going to achieve for next week?'''\\
