60 | | === Complete basic cartography suite in GRASS GIS wxGUI Map Display === |
61 | | |
62 | | * With few additions the wxGUI Map Display could cover large number of cartography needs so that users wouldn't be forced to switch to [http://grasswiki.osgeo.org/wiki/WxGUI_Cartographic_Composer WxGUI Cartographic Composer] or different software (Inkscape, QGIS) to create fully-featured map usable, e.g. for scientific publications. The development can happen in phases so that the easy-to-implement things, which gives greatest gain, are done first in case it is not possible to implement everything during summer. |
63 | | * first phase: |
64 | | * store legend, scale bar, north arrow and text (and others if added) in workspace (#2369) |
65 | | * add units to legend (optionally also title) as parameter |
66 | | * possibility to add any image (as in animation tool), use cases: logo/watermark, workaround for overview maps |
67 | | * disable rendering when adding multiple layers into layer manager using ''Add multiple...'' (disabled rendering when loading workspace already implemented in r63319) |
68 | | * determine map window size without the need to change map display size manually when loading workspace (currently there is a bug, when loading workspace, map display has correct size but map window is smaller and one must resize the window to get the right size of map window) |
69 | | * second phase: |
70 | | * support map units in scale bar, not only meters |
71 | | * allow user to set the length of scale bar (in map units) |
72 | | * manual breaks/ticks for legend (it is possible to set number of breaks/ticks but the values are not rounded), additional feature would be an option for automatic breaks/ticks every ten, hundred, ... |
73 | | * legend background (currently the legend has transparent background), additional features include rounded corners, border and opacity settings |
74 | | * general shapes |
75 | | * can be implemented using `d.*` commands (e.g. `d.graph`) or wxPython or both (wxPython might be easier for interactivity, `d.*` commands for scripting) |
76 | | * use cases: workaround missing background of legend or text, manual marking of special points |
77 | | * include map-display-like object |
78 | | * useful for overview maps (insets) or histograms |
79 | | * would be represented as image but the image would be dynamically generated |
80 | | * controlled using something like nested map display |
81 | | * might be implemented as a standard Map Display whose saved image would be inserted as an image, perhaps image from other Map Display can be used |
82 | | * the important feature is the user does not have to create an intermediate file |
83 | | * Simple Layer Manager classes can be used to manage layers in the additional/nested map display |
84 | | * third phase: |
85 | | * implement vector legend: |
86 | | * Perhaps we can find some workaround (i.e. some easy implementation) and wrap it into a module, e.g. vector legend drawn as vector with attribute table (enables even line with border thanks to different vector layers). |
87 | | * May get complicated with (enhancements of) vector thematic mapping |
88 | | * enhance `d.vect.thematic` |
89 | | * make `d.text`, `d.graph`, `d.erase` and perhaps other existing `d.*` modules accessible from wxGUI |
90 | | * implement module which can parametrize workspace (similarly as `g.gui.animation` is doing for 3D View) and render it with different maps |
91 | | * if the implementation would be wxPython free (ideal option) then it would have to translate some wxPython/wxGUI specific things to plain `d.*` commands |
92 | | * this can be also implemented as a script generator (rather than workspace renderer) |
93 | | * it should work as a simple automatic map ("atlas") generator and should accept also time series as the input |
94 | | * general system and (GUI) manager for additional object on map display |
95 | | * should support multiple legends and scale bars |
96 | | * should include general shapes |
97 | | * should work with any `d.*` commands, e.g. `d.histogram` |
98 | | * It would be great to make as much things as possible to work also in 3D Views (wxNVIZ). |
99 | | * Thorough (manual) testing on different platforms and version of wxPython is needed (by student or mentors). |
100 | | * See also: |
101 | | * [wiki:GSoC/2014#GRASSGISMapdisplaydecorationsenhancements map decorations idea from last year] |
102 | | * [wiki:GSoC/2014#VectorlegendforGRASSGIS vector legend idea from last year] |
103 | | * #2582 (implement `d.vect.thematic2` addon module features in `d.vect.thematic` core module) |
104 | | * [http://lists.osgeo.org/pipermail/grass-dev/2015-January/072918.html grass-dev future of thematic mapping in GRASS] |
105 | | * [http://lists.osgeo.org/pipermail/grass-dev/2010-March/049414.html grass-dev future thematic cartography in GRASS] |
106 | | * [wiki:GSoC/2014#ColortablemanagementGRASSGISwxGUI slightly related color tables idea from last year] |
107 | | * #2080 (changing properties of scale bar or legend) |
108 | | * Language requirements: Python, wxPython, C and OpenGL will be needed for some parts |
109 | | * Co-mentors: Anna Petrasova, Helena Mitasova, Martin Landa, Vaclav Petras |
110 | | * Accepted student: Adam Laza |
111 | | * Accepted project page: wiki:GSoC/2016/BasicCartographySuiteInGRASS |
112 | | |
113 | | |
140 | | |
141 | | === Web-based GUI for GRASS GIS === |
142 | | |
143 | | * This idea will consist in building a web application "WebGRASS" which allows to run GRASS modules on modern browsers. |
144 | | * The user interface for WebGRASS will be built using [http://www.webtoolkit.eu/wt Wt], Web Toolkit. |
145 | | * WT provides C++ API for developing web widgets. |
146 | | * Each grass module is described by an XML file generated the module's ''--interface-description'' parameter, the xml file is then parsed to generate the Module Form interface. |
147 | | * Parsing of the xml file and generating tokens is already available in GRASS GIS. |
148 | | * The main User Interface will be composed by: |
149 | | * Auth-module (user log-in) |
150 | | * mapset-location wizard |
151 | | * map canvas (based on openlayers) |
152 | | * menu bar with same layout of grass desktop |
153 | | * toolbar with: |
154 | | - pan |
155 | | - query |
156 | | - zoom in - out - to bbox - to layer - to region |
157 | | - save to img mapcanvas |
158 | | - save display extent to region |
159 | | * Command line prompt (a GRASS shell based on IPython Notebook) |
160 | | * Security concerns |
161 | | * By default Web-GRASS is designed to allow access to trusted users. |
162 | | * Each user will be an UNIX user on the server with his own home. |
163 | | * The web-grass UI interface will be accessible through an opportune registration/auth/login framework. |
164 | | * The communication over the network will be encrypted using HTTPS. |
165 | | * The input parameters will be parsed and sanitized, this will be part of the UI itself, based on the [http://grass.osgeo.org/programming7/gislib_cmdline_parsing.html GRASS command-line parsing] |
166 | | * Will be choice of deployment team to decide to adopt any 'Extra security layer'. This can be achieved using tools like: |
167 | | * [https://www.docker.io/ docker] |
168 | | * [https://linuxcontainers.org/ lxc] |
169 | | * [http://supervisord.org/ supervisors] |
170 | | * [http://publib.boulder.ibm.com/infocenter/pseries/v5r3/index.jsp?topic=/com.ibm.aix.cmds/doc/aixcmds5/ulimit.htm ulimit] |
171 | | * Discussion on the grass-dev mailing-list [http://lists.osgeo.org/pipermail/grass-dev/2014-March/067665.html GRASS GIS Web UI] |
172 | | * Detailed [http://www.google-melange.com/gsoc/proposal/public/google/gsoc2014/massimo_di_stefano/5685265389584384 Idea description] |
173 | | * [wiki:GSoC/2014/WebGRASS page for more broad idea description including alternatives] (unfinished) |
174 | | * Language requirements: C++, HTML5, Javascript |
175 | | * Mentor: Rashad Kanavath |
176 | | * Co-Mentor: ? |
177 | | * Sample !PyWt implementation to call GRASS commands from a !PyWt web UI by [http://wiki.osgeo.org/wiki/User:Epifanio Massimo Di Stefano] |
178 | | * [https://github.com/epifanio/wgrass source code] |
