Changes between Version 57 and Version 58 of GSoC/2016/Additional_segmentation_algorithms/weekly_report
- Jun 12, 2016, 8:55:18 PM (8 years ago)
v57 v58 149 149 g.region raster=lsat7_2000_80 -p 150 150 i.segment --o group=singleband_yb threshold=0.5 output=testout_ms_yb3 method=mean_shift 151 }}} sometimes it can output normally to console, but sometimes the output doesn't make sense. Two cases are random appeared and the ratio is about 1:1. I didn't change anything between running. I tried using that 8x8 image chip (import as raster) and the same thing happened. 151 }}} 152 sometimes it can output normally to console, but sometimes the output doesn't make sense. Two cases are random appeared and the ratio is about 1:1. I didn't change anything between running. I tried using that 8x8 image chip (import as raster) and the same thing happened.
