19 | | === What do you plan on doing next week? === |
20 | | === Are you blocked on anything? === |
21 | | * A small exercise too get more familiar with basic GRASS code |
22 | | >>Moritz: |
23 | | >> |
24 | | >>As as part of bonding period, and as you are now able to compile GRASS, I would like to propose a small exercise which is already a first step in the direction of your project and which should allow you to become a bit more familiar with the code and with coding practices: As currently i.segment only provides one algorithm, the entire layout of the module GUI is related to that one algorithm. In the attached screenshot you see the current GUI. My idea would be to have the three mandatory inputs in the Required tab, then one tab per algorithm with algorithm-specific parameters, then the Optional tab. Otherwise, I'm afraid that the current'Settings' tab becomes overcrowded. |
25 | | >> |
26 | | >>The code that defines options and which 'guisection' they are in is in parse_args.c [1]. For more info about how the command parser and its options work, see [2], but the existing examples in the code might already be enough. |
27 | | >> |
28 | | >>You can add new parameters there without them being used in the code, yet, so don't hesitate, at this stage, to add one phony parameter per new algorithm, just to get the relevant tabs. |
29 | | >> |
30 | | >>Once you've done this, compile just the i.segment module (by running make in the directory) and see if the GUI corresponds to what you aim for. Then, send me a diff of the code. |
31 | | |
32 | | * Finish the exercise to adding more parameters to the i.segment |
33 | | >Bo: |
34 | | > |
35 | | >I think I've finished the exercise. For the time being I applied the following changes to the module GUI: |
36 | | >1. I kept "required" tab and add the selection of algorithms. Because I think for all of the three algorithms the input data and output location are required, so this tab now is designed for the inputs and outputs for all three algorithms |
37 | | >2. The "setting" tab has been changed to the setting of "region growth" since previously it only provided the setting of that algorithm. |
38 | | >3. Two Tabs of "shift_mean" and "watershed" were added to input the setting of each algorithm. I just give some preliminary input parameters for them, when we start coding I will give more >substantial parameters required in the algorithm. |
39 | | >The user are supposed to give the input, output, and select which algorithm are utilized. Then define settings of that algorithm in the corresponding tab. The option tab are supposed to be additional settings. Please see attached pics for new GUI and advise if you think this setting logistic works. |
| 19 | * Finished A small exercise too get more familiar with basic GRASS code |
| 20 | Because currently i.segment only provides one algorithm, the entire layout of the module GUI is related to that one algorithm. By modifying the codes in [https://trac.osgeo.org/grass/browser/sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c parse_args.c] I added three inputs in the Required tab, then one tab per algorithm with algorithm-specific parameters. |
47 | | * Discussion about the algorithm and literature |
48 | | >>Markus: |
49 | | >> |
50 | | >>I was reading through the literature that Moritz sent and think that the implementation of mean shift is relatively easy. The most complicated part is figuring out a method for adaptive bandwidth where the spatial and the range bandwidth might need to be adapted differently. |
51 | | >>As far as I understand, the mean shift method consists of two parts 1. change band values to become more similar to neighboring cells by use of a spatial and a range weighing kernel 2. identify connected components (cells with similar band values), this is also known as clusters or in GRASS as clumps (r.clump). For this part, a modified version of the r.clump code can be used |
52 | | >>All together, this seems much simpler than the current region growing method, e.g. the search trees used by region growing are not needed for mean shift. |
53 | | >> |
54 | | >>More technical: |
55 | | >>If I understand correctly, mean shift requires three parameters: |
56 | | >>spatial bandwidth, range (band value) bandwidth, and threshold to indicate when to stop adjusting band values (max difference < threshold). Apparently, result improve if the two bandwidths are adapted for each sampling window separately. As weighing function I suggest a Gauss kernel, this is already available at various places in the GRASS source code. For spatial weighing, a finite kernel is needed and the Gauss kernel is infinite. The spatial bandwidth could mean standard deviation in number of cells, the cap could be set at standard deviation times 3 or 4, making it a finite kernel. For the range weighing, an infinite Gauss kernel is fine because the range of observed values is restricted by the finite spatial kernel. See also r.resamp.filter which offers various finite and infinite kernels and an explanation of their difference. The existing methods to use either euclidean or manhattan distance can be used as is for mean shift. |
57 | | >>Suggested code structure for mean shift is in trunk r68482. |
58 | | >> |
59 | | >>The identification of connected components (neighboring cells with similar band value) would also need a threshold, maybe the same threshold as for the main mean shift algorithm can be used. |
60 | | >>Additionally, the already existing option to consider 4 or 8 neighbors can be acknowledged. |
61 | | >> |
62 | | >>I guess the mean shift algorithm will be faster and less memory intensive than the region growing algorithm. |
| 28 | * Some discussions were made about the algorithm and literature |
