Changes between Version 252 and Version 253 of CompileOnWindows
- Jul 22, 2013, 8:00:15 AM (11 years ago)
CompileOnWindows
v252 v253 16 16 3. Select `Advanced Install`, and `Next`. 17 17 18 4. Set the install directory to `c:\OSGeo4W` (other directories or fine if there are no spaces in the path but make sure to adjust the instructions below (?)). The MS ysmaintainers have made it clear that they [https://sourceforge.net/tracker/?func=detail&atid=102435&aid=1511614&group_id=2435 will not support spaces in path names] nor accept patches fixing those issues. With some patches to `msys.bat` however it is possible to install a built GRASS into `C:\Program Files\`.18 4. Set the install directory to `c:\OSGeo4W` (other directories or fine if there are no spaces in the path but make sure to adjust the instructions below (?)). The MSYS maintainers have made it clear that they [https://sourceforge.net/tracker/?func=detail&atid=102435&aid=1511614&group_id=2435 will not support spaces in path names] nor accept patches fixing those issues. With some patches to `msys.bat` however it is possible to install a built GRASS into `C:\Program Files\`. 19 19 20 20 5. Select '''grass''' (see [http://trac.osgeo.org/osgeo4w/wiki/pkg-grass pkg-grass] for details) from the desktop section (for dependencies, this is a binary but we'll compile from source later).
