Changes between Initial Version and Version 18 of Ticket #461
- Sep 27, 2018, 2:38:30 AM (6 years ago)
Ticket #461
- Property Status new → closed
- Property Cc added
- Property Summary v.db.update crashes with updating shapefile connected with v.external → v.to.db crashes on a shapefile connected with v.external
- Property Priority critical → major
- Property Version svn-develbranch6 → svn-trunk
- Property Milestone 6.4.0 → 7.0.7
- Property Keywords v.external v.to.db added
- Property Resolution → fixed
Ticket #461 – Description
initial v18 9 9 There is NO WARRANTY, to the extent permitted by law. Type "show copying" 10 10 and "show warranty" for details. 11 This GDB was configured as "x86_64-linux-gnu"...11 This GDB was configured as https://trac.osgeo.org/grass/ticket/461#no3"x86_64-linux-gnu"... 12 12 (gdb) run map=gshhs_shp opt=area units=k col=AREA 13 13 Starting program: /usr/local/grass-6.5.svn/bin/v.to.db map=gshhs_shp opt=area units=k col=AREA
