37 | | The GEOS project does not guarantee ABI stability of the C++ API during minor updates. This means your code may need recompilation or changes to upgrade to next minor version of GEOS. If you want ABI stability from minor version to minor version, you should use the C-API instead. |
| 37 | The GEOS project does not guarantee ABI stability of the C++ API during minor updates. |
| 38 | This means your code may need recompilation or changes to upgrade to next minor version of GEOS. |
| 39 | If you want ABI stability from minor version to minor version, you should use the C-API instead. |
