Changes between Version 6 and Version 7 of BuildingOnMINGW64CMake
- Jun 10, 2013, 2:39:10 PM (11 years ago)
v6 v7 48 48 export GEOS_VER=3.4.0dev 49 49 tools/svn_repo_revision.sh 50 rm -rf build/mingw 51 mkdir -p build/mingw 52 cd build/mingw 50 cd .. 51 rm -rf build 52 mkdir -p build 53 cd build 53 54 54 55 ## if building for windows 64-bit you need to add the -DHAVE_LONG_LONG_INT_64 55 56 ## because geos for some reason can't figure this out 56 57 ## (for 32-bit you should leave it out) 57 ## Also not that the -DGEOS_ENABLE_INLINE=ON should in theory work but doesn't seem to58 ## without -DGEOS_ENABLE_INLINE=NO get linker failurresss with complete of duplicate .inl 58 59 ## fully so it doesn't matter if you put it in since i have it hardcoded in my patch for mingw64 59 60 ## geos in theory should be able to figure out that -DHAVE_STD_ISNAN too but can't for mingw64 (both 32-bit and 64-bit chains) 60 61 61 cmake -G "MSYS Makefiles" ../trunk -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE= ON-DGEOS_ENABLE_TESTS=ON62 cmake -G "MSYS Makefiles" ../trunk -DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD} -DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=NO -DGEOS_ENABLE_TESTS=ON 62 63 make 63 64 make test
