Changes between Version 1 and Version 2 of WikiRestructuredText
- 06/10/10 13:36:22 (15 years ago)
v1 v2 6 6 "''reStructuredText is an easy-to-read, what-you-see-is-what-you-get plaintext markup syntax and parser system. It is useful for in-line program documentation (such as Python docstrings), for quickly creating simple web pages, and for standalone documents. reStructuredText is designed for extensibility for specific application domains. ''" 7 7 8 If you want a file from your Subversion repository be displayed as reStructuredText in Trac's source browser, set `text/x-rst` as value for the Subversion property `svn:mime-type`. See [trac:source:/trunk/INSTALL this example]. 9 8 10 === Requirements === 9 11 Note that to activate RST support in Trac, the python docutils package must be installed. 10 12 If not already available on your operating system, you can download it at the [http://docutils.sourceforge.net/rst.html RST Website]. 13 14 Install docutils using `easy_install docutils`. Do not use the package manager of your OS (e.g. `apt-get install python-docutils`), because Trac will not find docutils then. 11 15 12 16 === More information on RST === … … 22 26 === TracLinks in reStructuredText === 23 27 24 * Trac provides a custom RST reference-directive 'trac'to allow TracLinks from within RST text.28 * Trac provides a custom RST directive `trac::` to allow TracLinks from within RST text. 25 29 26 30 Example: … … 34 38 }}} 35 39 36 For a complete example of all uses of the ''trac''-directive, please see WikiRestructuredTextLinks. 37 38 39 * Trac allows an even easier way of creating TracLinks in RST, using the custom '':trac:'' link naming scheme. 40 * Trac allows an even easier way of creating TracLinks in RST, using the custom `:trac:` role. 40 41 41 42 Example: … … 49 50 }}} 50 51 52 For a complete example of all uses of the `:trac:` role, please see WikiRestructuredTextLinks. 53 54 51 55 === Syntax highlighting in reStructuredText === 52 56 53 There is a directive for doing TracSyntaxColoring in R eST as well. The directive is called57 There is a directive for doing TracSyntaxColoring in RST as well. The directive is called 54 58 code-block 55 59 … … 84 88 }}} 85 89 86 === Wiki Macros in reStructuredText ===90 === Wiki Macros in reStructuredText === 87 91 88 For doing WikiMacros in ReST you use the same directive as for syntax highlightning i.e89 code-block. To work you must use a version of trac that has #801applied.92 For doing [WikiMacros Wiki Macros] in RST you use the same directive as for syntax highlighting i.e 93 code-block. To work you must use a version of trac that has [trac:ticket:801 #801] applied. 90 94 91 === Wiki Macro Example ===95 === Wiki Macro Example === 92 96 93 97 {{{ … … 95 99 #!rst 96 100 97 .. code-block:: HelloWorld 98 99 Something I wanted to say 101 .. code-block:: RecentChanges 100 102 103 Trac,3 101 104 102 105 }}} 103 106 }}} 104 107 105 Will result in the below .108 Will result in the below: 106 109 107 [[HelloWorld(Something I wanted to say)]]110 [[RecentChanges(Trac,3)]] 108 111 112 Or a more concise Wiki Macro like syntax is also available: 109 113 110 === Bigger ReST Example === 114 {{{ 115 {{{ 116 #!rst 117 118 :code-block:`RecentChanges:Trac,3` 119 }}} 120 }}} 121 122 === Bigger RST Example === 111 123 The example below should be mostly self-explanatory: 112 124 {{{
