Changes between Version 2 and Version 3 of WikiMacros
- May 4, 2015, 1:51:23 PM (9 years ago)
WikiMacros
v2 v3 1 = Trac Macros =1 = Trac Macros 2 2 3 3 [[PageOutline]] 4 4 5 Trac macros are plugins to extend the Trac engine with custom 'functions' written in Python. A macro inserts dynamic HTML data in any context supporting WikiFormatting. 5 Trac macros are plugins to extend the Trac engine with custom 'functions' written in Python. A macro inserts dynamic HTML data in any context supporting WikiFormatting. Its syntax is `[[macro-name(optional-arguments)]]`. 6 6 7 Another kind of macros are WikiProcessors. They typically deal with alternate markup formats and representation of larger blocks of information (like source code highlighting).7 The WikiProcessors are another kind of macros. They typically deal with alternate markup formats and transformation of larger "blocks" of information, like source code highlighting. They are used for processing the multiline `{{{#!wiki-processor-name ... }}}` blocks. 8 8 9 == Using Macros == 10 Macro calls are enclosed in two ''square brackets''. Like Python functions, macros can also have arguments, a comma separated list within parentheses. 9 == Using Macros 11 10 12 Trac macros can also be written as TracPlugins. This gives them some capabilities that macros do not have, such as being able to directly access the HTTP request.11 Macro calls are enclosed in two ''square brackets'' `[[..]]`. Like Python functions, macros can also have arguments, a comma separated list within parentheses `[[..(,)]]`. 13 12 14 === Example ===13 === Getting Detailed Help 15 14 16 A list of 3 most recently changed wiki pages starting with 'Trac': 15 The list of available macros and the full help can be obtained using the !MacroList macro, as seen [#AvailableMacros below]. 17 16 18 {{{ 19 [[RecentChanges(Trac,3)]] 17 A brief list can be obtained via `[[MacroList(*)]]` or `[[?]]`. 18 19 Detailed help on a specific macro can be obtained by passing it as an argument to !MacroList, e.g. `[[MacroList(MacroList)]]`, or, more conveniently, by appending a question mark (`?`) to the macro's name, like in `[[MacroList?]]`. 20 21 === Example 22 23 A list of the 3 most recently changed wiki pages starting with 'Trac': 24 25 ||= Wiki Markup =||= Display =|| 26 {{{#!td 27 {{{ 28 [[RecentChanges(Trac,3)]] 29 }}} 30 }}} 31 {{{#!td style="padding-left: 2em;" 32 [[RecentChanges(Trac,3)]] 33 }}} 34 |----------------------------------- 35 {{{#!td 36 {{{ 37 [[RecentChanges?(Trac,3)]] 38 }}} 39 }}} 40 {{{#!td style="padding-left: 2em;" 41 [[RecentChanges?(Trac,3)]] 42 }}} 43 |----------------------------------- 44 {{{#!td 45 {{{ 46 [[?]] 47 }}} 48 }}} 49 {{{#!td style="padding-left: 2em" 50 {{{#!html 51 <div style="font-size: 80%" class="trac-macrolist"> 52 <h3><code>[[Image]]</code></h3>Embed an image in wiki-formatted text. 53 54 The first argument is the file … 55 <h3><code>[[InterTrac]]</code></h3>Provide a list of known <a class="wiki" href="/wiki/InterTrac">InterTrac</a> prefixes. 56 <h3><code>[[InterWiki]]</code></h3>Provide a description list for the known <a class="wiki" href="/wiki/InterWiki">InterWiki</a> prefixes. 57 <h3><code>[[KnownMimeTypes]]</code></h3>List all known mime-types which can be used as <a class="wiki" href="/wiki/WikiProcessors">WikiProcessors</a>. 58 Can be …</div> 59 }}} 60 etc. 20 61 }}} 21 62 22 Display: 23 [[RecentChanges(Trac,3)]] 24 25 == Available Macros == 63 == Available Macros 26 64 27 65 ''Note that the following list will only contain the macro documentation if you've not enabled `-OO` optimizations, or not set the `PythonOptimize` option for [wiki:TracModPython mod_python].'' … … 29 67 [[MacroList]] 30 68 31 == Macros from around the world ==69 == Macros from around the world 32 70 33 The [http://trac-hacks.org/ Trac Hacks] site provides a wide collection of macros and other Trac [TracPlugins plugins] contributed by the Trac community. If you 're looking for new macros, or have written one that you'd like to share with the world, pleasedon't hesitate to visit that site.71 The [http://trac-hacks.org/ Trac Hacks] site provides a wide collection of macros and other Trac [TracPlugins plugins] contributed by the Trac community. If you are looking for new macros, or have written one that you would like to share with the world, don't hesitate to visit that site. 34 72 35 == Developing Custom Macros == 36 Macros, like Trac itself, are written in the [http://python.org/ Python programming language]. 73 == Developing Custom Macros 74 75 Macros, like Trac itself, are written in the [http://python.org/ Python programming language] and are developed as part of TracPlugins. 37 76 38 77 For more information about developing macros, see the [trac:TracDev development resources] on the main project site. 39 78 79 Here are 2 simple examples showing how to create a Macro. Also, have a look at [trac:source:tags/trac-1.0.2/sample-plugins/Timestamp.py Timestamp.py] for an example that shows the difference between old style and new style macros and at the [trac:source:tags/trac-0.11/wiki-macros/README macros/README] which provides a little more insight about the transition. 40 80 41 == Implementation ==81 === Macro without arguments 42 82 43 Here are 2 simple examples showing how to create a Macro with Trac 0.11. 44 45 Also, have a look at [trac:source:tags/trac-0.11/sample-plugins/Timestamp.py Timestamp.py] for an example that shows the difference between old style and new style macros and at the [trac:source:tags/trac-0.11/wiki-macros/README macros/README] which provides a little more insight about the transition. 46 47 === Macro without arguments === 48 It should be saved as `TimeStamp.py` (in the TracEnvironment's `plugins/` directory) as Trac will use the module name as the Macro name. 83 To test the following code, you should saved it in a `timestamp_sample.py` file located in the TracEnvironment's `plugins/` directory. 49 84 {{{ 50 85 #!python … … 63 98 url = "$URL$" 64 99 65 def expand_macro(self, formatter, name, args):100 def expand_macro(self, formatter, name, text): 66 101 t = datetime.now(utc) 67 return tag. b(format_datetime(t, '%c'))102 return tag.strong(format_datetime(t, '%c')) 68 103 }}} 69 104 70 === Macro with arguments === 71 It should be saved as `HelloWorld.py` (in the TracEnvironment's `plugins/` directory) as Trac will use the module name as the Macro name. 105 === Macro with arguments 106 107 To test the following code, you should save it in a `helloworld_sample.py` file located in the TracEnvironment's `plugins/` directory. 72 108 {{{ 73 109 #!python 110 from genshi.core import Markup 111 74 112 from trac.wiki.macros import WikiMacroBase 75 113 … … 89 127 url = "$URL$" 90 128 91 def expand_macro(self, formatter, name, args):129 def expand_macro(self, formatter, name, text, args): 92 130 """Return some output that will be displayed in the Wiki content. 93 131 94 132 `name` is the actual name of the macro (no surprise, here it'll be 95 133 `'HelloWorld'`), 96 ` args` is the text enclosed in parenthesis at the call of the macro.134 `text` is the text enclosed in parenthesis at the call of the macro. 97 135 Note that if there are ''no'' parenthesis (like in, e.g. 98 [[HelloWorld]]), then `args` is `None`. 136 [[HelloWorld]]), then `text` is `None`. 137 `args` are the arguments passed when HelloWorld is called using a 138 `#!HelloWorld` code block. 99 139 """ 100 return 'Hello World, args = ' + unicode(args) 101 102 # Note that there's no need to HTML escape the returned data, 103 # as the template engine (Genshi) will do it for us. 140 return 'Hello World, text = %s, args = %s' % \ 141 (Markup.escape(text), Markup.escape(repr(args))) 142 104 143 }}} 105 144 145 Note that `expand_macro` optionally takes a 4^th^ parameter ''`args`''. When the macro is called as a [WikiProcessors WikiProcessor], it's also possible to pass `key=value` [WikiProcessors#UsingProcessors processor parameters]. If given, those are stored in a dictionary and passed in this extra `args` parameter. On the contrary, when called as a macro, `args` is `None`. (''since 0.12''). 106 146 107 === {{{expand_macro}}} details === 108 {{{expand_macro}}} should return either a simple Python string which will be interpreted as HTML, or preferably a Markup object (use {{{from trac.util.html import Markup}}}). {{{Markup(string)}}} just annotates the string so the renderer will render the HTML string as-is with no escaping. You will also need to import Formatter using {{{from trac.wiki import Formatter}}}. 147 For example, when writing: 148 {{{ 149 {{{#!HelloWorld style="polite" -silent verbose 150 <Hello World!> 151 }}} 109 152 110 If your macro creates wiki markup instead of HTML, you can convert it to HTML like this: 153 {{{#!HelloWorld 154 <Hello World!> 155 }}} 156 157 [[HelloWorld(<Hello World!>)]] 158 }}} 159 One should get: 160 {{{ 161 Hello World, text = <Hello World!> , args = {'style': u'polite', 'silent': False, 'verbose': True} 162 Hello World, text = <Hello World!> , args = {} 163 Hello World, text = <Hello World!> , args = None 164 }}} 165 166 Note that the return value of `expand_macro` is '''not''' HTML escaped. Depending on the expected result, you should escape it by yourself (using `return Markup.escape(result)`) or, if this is indeed HTML, wrap it in a Markup object (`return Markup(result)`) with `Markup` coming from Genshi, (`from genshi.core import Markup`). 167 168 You can also recursively use a wiki Formatter (`from trac.wiki import Formatter`) to process the `text` as wiki markup: 111 169 112 170 {{{ 113 171 #!python 114 text = "whatever wiki markup you want, even containing other macros" 115 # Convert Wiki markup to HTML, new style 116 out = StringIO() 117 Formatter(self.env, formatter.context).format(text, out) 118 return Markup(out.getvalue()) 172 from genshi.core import Markup 173 from trac.wiki.macros import WikiMacroBase 174 from trac.wiki import Formatter 175 import StringIO 176 177 class HelloWorldMacro(WikiMacroBase): 178 def expand_macro(self, formatter, name, text, args): 179 text = "whatever '''wiki''' markup you want, even containing other macros" 180 # Convert Wiki markup to HTML, new style 181 out = StringIO.StringIO() 182 Formatter(self.env, formatter.context).format(text, out) 183 return Markup(out.getvalue()) 119 184 }}}
