Changes between Version 1 and Version 2 of TracPermissions
- Jun 10, 2010, 1:36:22 PM (14 years ago)
TracPermissions
v1 v2 2 2 [[TracGuideToc]] 3 3 4 Trac uses a simple permission system to control what users can and can't access.4 Trac uses a simple, case sensitive, permission system to control what users can and can't access. 5 5 6 Permission privileges are managed using the [wiki:TracAdmin trac-admin] tool. 6 Permission privileges are managed using the [TracAdmin trac-admin] tool or (new in version 0.11) the ''General / Permissions'' panel in the ''Admin'' tab of the web interface. 7 8 In addition to the default permission policy described in this page, it is possible to activate additional permission policies by enabling plugins and listing them in the `[trac] permission_policies` configuration entry in the TracIni. See TracFineGrainedPermissions for more details. 7 9 8 10 Non-authenticated users accessing the system are assigned the name "anonymous". Assign permissions to the "anonymous" user to set privileges for anonymous/guest users. The parts of Trac that a user does not have the privileges for will not be displayed in the navigation. 11 In addition to these privileges, users can be granted additional individual rights in effect when authenticated and logged into the system. All logged in users belong to the virtual group "authenticated", which inherits permissions from "anonymous". 9 12 10 In addition to these privileges, users can be granted additional individual rights in effect when authenticated and logged into the system. All logged in users belong to the virtual group "authenticated", which inherits permissions from "anonymous". 13 == Graphical Admin Tab == 14 ''This feature is new in version 0.11.'' 15 16 To access this tab, a user must have `TRAC_ADMIN privileges`. This can be performed as follows (more on the trac-admin script below): 17 {{{ 18 $ trac-admin /path/to/projenv permission add bob TRAC_ADMIN 19 }}} 20 21 Then, the user `bob` will be able to see the Admin tab, and can then access the permissions menu. This menu will allow you to perform all the following actions, but from the browser without requiring root access to the server (just the correct permissions for your user account). 22 23 24 An easy way to quickly secure a new Trac install is to run the above command on the anonymous user, install the [http://trac-hacks.org/wiki/AccountManagerPlugin AccountManagerPlugin], create a new admin account graphically and then remove the TRAC_ADMIN permission from the anonymous user. 11 25 12 26 == Available Privileges == 13 27 14 To enable all privileges for a user, use the `TRAC_ADMIN` permission. Having `TRAC_ADMIN` is like being `root` on a *NIX system , it will allow youperform any operation.28 To enable all privileges for a user, use the `TRAC_ADMIN` permission. Having `TRAC_ADMIN` is like being `root` on a *NIX system: it will allow you to perform any operation. 15 29 16 Otherwise, individual privileges can be assigned to users for the various different functional areas of Trac ( note that the privilege names are case-sensitive):30 Otherwise, individual privileges can be assigned to users for the various different functional areas of Trac ('''note that the privilege names are case-sensitive'''): 17 31 18 32 === Repository Browser === … … 28 42 || `TICKET_CREATE` || Create new [wiki:TracTickets tickets] || 29 43 || `TICKET_APPEND` || Add comments or attachments to [wiki:TracTickets tickets] || 30 || `TICKET_CHGPROP` || Modify [wiki:TracTickets ticket] properties (priority, assignment, keywords, etc.) except description field || 31 || `TICKET_MODIFY` || Includes both `TICKET_APPEND` and `TICKET_CHGPROP`, and in addition allows resolving [wiki:TracTickets tickets] || 32 || `TICKET_ADMIN` || All `TICKET_*` permissions, plus the deletion of ticket attachments and modification of the description field || 44 || `TICKET_CHGPROP` || Modify [wiki:TracTickets ticket] properties (priority, assignment, keywords, etc.) with the following exceptions: edit description field, add/remove other users from cc field when logged in, and set email to pref || 45 || `TICKET_MODIFY` || Includes both `TICKET_APPEND` and `TICKET_CHGPROP`, and in addition allows resolving [wiki:TracTickets tickets]. Tickets can be assigned to users through a [TracTickets#Assign-toasDrop-DownList drop-down list] when the list of possible owners has been restricted. || 46 || `TICKET_EDIT_CC` || Full modify cc field || 47 || `TICKET_EDIT_DESCRIPTION` || Modify description field || 48 || `TICKET_ADMIN` || All `TICKET_*` permissions, plus the deletion of ticket attachments and modification of the reporter and description fields. It also allows managing ticket properties in the WebAdmin panel. || 49 50 Attention: the "view tickets" button appears with the `REPORT_VIEW` permission. 33 51 34 52 === Roadmap === 35 53 36 || `MILESTONE_VIEW` || View a milestone||54 || `MILESTONE_VIEW` || View milestones and assign tickets to milestones. || 37 55 || `MILESTONE_CREATE` || Create a new milestone || 38 56 || `MILESTONE_MODIFY` || Modify existing milestones || 39 57 || `MILESTONE_DELETE` || Delete milestones || 40 58 || `MILESTONE_ADMIN` || All `MILESTONE_*` permissions || 41 || `ROADMAP_VIEW` || View the [wiki:TracRoadmap roadmap] page || 59 || `ROADMAP_VIEW` || View the [wiki:TracRoadmap roadmap] page, is not (yet) the same as MILESTONE_VIEW, see [trac:#4292 #4292] || 60 || `ROADMAP_ADMIN` || to be removed with [trac:#3022 #3022], replaced by MILESTONE_ADMIN || 42 61 43 62 === Reports === 44 63 45 || `REPORT_VIEW` || View [wiki:TracReports reports] ||64 || `REPORT_VIEW` || View [wiki:TracReports reports], i.e. the "view tickets" link. || 46 65 || `REPORT_SQL_VIEW` || View the underlying SQL query of a [wiki:TracReports report] || 47 66 || `REPORT_CREATE` || Create new [wiki:TracReports reports] || … … 58 77 || `WIKI_ADMIN` || All `WIKI_*` permissions, plus the management of ''readonly'' pages. || 59 78 79 === Permissions === 80 81 || `PERMISSION_GRANT` || add/grant a permission || 82 || `PERMISSION_REVOKE` || remove/revoke a permission || 83 || `PERMISSION_ADMIN` || All `PERMISSION_*` permissions || 84 85 60 86 === Others === 61 87 … … 63 89 || `SEARCH_VIEW` || View and execute [wiki:TracSearch search] queries || 64 90 || `CONFIG_VIEW` || Enables additional pages on ''About Trac'' that show the current configuration or the list of installed plugins || 91 || `EMAIL_VIEW` || Shows email addresses even if [trac:wiki:0.11/TracIni trac show_email_addresses configuration option is false] || 65 92 66 93 == Granting Privileges == … … 81 108 }}} 82 109 110 Or add all privileges: 111 {{{ 112 $ trac-admin /path/to/projenv permission add bob TRAC_ADMIN 113 }}} 114 83 115 == Permission Groups == 116 117 There are two built-in groups, "authenticated" and "anonymous".[[BR]] 118 Any user who has not logged in is automatically in the "anonymous" group.[[BR]] 119 Any user who has logged in is also in the "authenticated" group.[[BR]] 120 The "authenticated" group inherits permissions from the "anonymous" group.[[BR]] 121 eg. if the "anonymous" group has permission WIKI_MODIFY, it's not necessary to add the WIKI_MODIFY permisison to the "authenticated" group as well. 122 123 Custom groups may be defined that inherit permissions from the two built-in groups. 84 124 85 125 Permissions can be grouped together to form roles such as ''developer'', ''admin'', etc. … … 92 132 }}} 93 133 94 Group membership can be checked by doing a {{{permission list}}} with no further arguments; the resulting output will include group memberships. Use lowercase for group names, as uppercase is reserved for permissions. 134 Group membership can be checked by doing a {{{permission list}}} with no further arguments; the resulting output will include group memberships. '''Use lowercase for group names, as uppercase is reserved for permissions'''. 135 136 == Adding a New Group and Permissions == 137 Permission groups can be created by assigning a user to a group you wish to create, then assign permissions to that group. 138 139 The following will add ''bob'' to the new group called ''beta_testers'' and then will assign WIKI_ADMIN permissions to that group. (Thus, ''bob'' will inherit the WIKI_ADMIN permission) 140 {{{ 141 $ trac-admin /path/to/projenv permission add bob beta_testers 142 $ trac-admin /path/to/projenv permission add beta_testers WIKI_ADMIN 143 144 }}} 95 145 96 146 == Removing Permissions == … … 107 157 You can also remove all privileges for a specific user: 108 158 {{{ 109 $ trac-admin /path/to/projenv permission remove bob *159 $ trac-admin /path/to/projenv permission remove bob '*' 110 160 }}} 111 161 112 162 Or one privilege for all users: 113 163 {{{ 114 $ trac-admin /path/to/projenv permission remove *REPORT_ADMIN164 $ trac-admin /path/to/projenv permission remove '*' REPORT_ADMIN 115 165 }}} 116 166 117 167 == Default Permissions == 118 168 119 Granting privileges to the special user ''anonymous'' can be used to control what an anonymous user can do before they have logged in. 169 By default on a new Trac installation, the `anonymous` user will have ''view'' access to everything in Trac, but will not be able to create or modify anything. 170 On the other hand, the `authenticated` users will have the permissions to ''create and modify tickets and wiki pages''. 120 171 121 In the same way, privileges granted to the special user ''authenticated'' will apply to any authenticated (logged in) user. 172 '''anonymous''' 173 {{{ 174 BROWSER_VIEW 175 CHANGESET_VIEW 176 FILE_VIEW 177 LOG_VIEW 178 MILESTONE_VIEW 179 REPORT_SQL_VIEW 180 REPORT_VIEW 181 ROADMAP_VIEW 182 SEARCH_VIEW 183 TICKET_VIEW 184 TIMELINE_VIEW 185 WIKI_VIEW 186 }}} 122 187 188 '''authenticated''' 189 {{{ 190 TICKET_CREATE 191 TICKET_MODIFY 192 WIKI_CREATE 193 WIKI_MODIFY 194 }}} 123 195 ---- 124 See also: TracAdmin, TracGuide and [http://trac.edgewall.org/wiki/FineGrainedPermissions FineGrainedPermissions]196 See also: TracAdmin, TracGuide and TracFineGrainedPermissions
