Changes between Version 2 and Version 3 of TracFineGrainedPermissions
02/01/17 00:35:40 (8 years ago)
  • TracFineGrainedPermissions
    v2 v3
    1515{{{#!ini
    1616[trac]
    17 permission_policies = AuthzSourcePolicy, DefaultPermissionPolicy, LegacyAttachmentPolicy
    18 }}}
    19 This lists the [#AuthzSourcePolicy] described below as the first policy, followed by the !DefaultPermissionPolicy which checks for the traditional coarse grained style permissions described in TracPermissions, and the !LegacyAttachmentPolicy which knows how to use the coarse grained permissions for checking the permissions available on attachments.
     17permission_policies = ReadonlyWikiPolicy, DefaultPermissionPolicy, LegacyAttachmentPolicy
     18}}}
     19This lists the [#ReadonlyWikiPolicy] which controls readonly access to wiki pages, followed by the !DefaultPermissionPolicy which checks for the traditional coarse grained style permissions described in TracPermissions, and the !LegacyAttachmentPolicy which knows how to use the coarse grained permissions for checking the permissions available on attachments.
    2020
    2121Among the optional choices, there is [#AuthzPolicy], a very generic permission policy, based on an Authz-style system. See
    2828=== !AuthzPolicy ===
    2929==== Configuration ====
    30 * Install [http://www.voidspace.org.uk/python/configobj.html ConfigObj].
    3130* Put a [http://swapoff.org/files/authzpolicy.conf authzpolicy.conf] file somewhere, preferably on a secured location on the server, not readable for others than the webuser. If the  file contains non-ASCII characters, the UTF-8 encoding should be used.
    3231* Update your `trac.ini`:
    3534[trac]
    3635...
    37 permission_policies = AuthzPolicy, DefaultPermissionPolicy, LegacyAttachmentPolicy
     36permission_policies = AuthzPolicy, ReadonlyWikiPolicy, DefaultPermissionPolicy, LegacyAttachmentPolicy
    3837}}}
    3938  1. add a new `[authz_policy]` section:
    223222==== Trac Configuration ====
    224223
    225 To activate granular permissions you __must__ specify the {{{authz_file}}} option in the {{{[trac]}}} section of trac.ini. If this option is set to null or not specified, the permissions will not be used.
    226
    227 {{{#!ini
    228 [trac]
     224To activate granular permissions you __must__ specify the {{{authz_file}}} option in the `[svn]` section of trac.ini. If this option is set to null or not specified, the permissions will not be used.
     225
     226{{{#!ini
     227[svn]
    229228authz_file = /path/to/svnaccessfile
    230229}}}
    236235}}}
    237236
    238 where ''modulename'' refers to the same repository indicated by the `repository_dir` entry in the `[trac]` section. As an example, if the `repository_dir` entry in the `[trac]` section is {{{/srv/active/svn/somemodule}}}, that would yield the following:
     237where ''modulename'' refers to the same repository indicated by the `<name>.dir` entry in the `[repositories]` section. As an example, if the `somemodule.dir` entry in the `[repositories]` section is `/srv/active/svn/somemodule`, that would yield the following:
    239238
    240239{{{ #!ini
    241 [trac]
     240[svn]
    242241authz_file = /path/to/svnaccessfile
    243242authz_module_name = somemodule
    244243...
    245 repository_dir = /srv/active/svn/somemodule
     244[repositories]
     245somemodule.dir = /srv/active/svn/somemodule
    246246}}}
    247247
    254254{{{#!ini
    255255[trac]
    256 permission_policies = AuthzSourcePolicy, DefaultPermissionPolicy, LegacyAttachmentPolicy
     256permission_policies = AuthzSourcePolicy, ReadonlyWikiPolicy, DefaultPermissionPolicy, LegacyAttachmentPolicy
    257257}}}
    258258
    272272For information about how to restrict access to entire projects in a multiple project environment see [trac:wiki:TracMultipleProjectsSVNAccess].
    273273
     274=== ReadonlyWikiPolicy
     275
     276Since 1.1.2, the read-only attribute of wiki pages is enabled and enforced when `ReadonlyWikiPolicy` is in the list of active permission policies. The default for new Trac installations in 1.1.2 and later is:
     277{{{
     278[trac]
     279permission_policies = ReadonlyWikiPolicy,
     280 DefaultPermissionPolicy,
     281 LegacyAttachmentPolicy
     282}}}
     283
     284When upgrading from earlier versions of Trac, `ReadonlyWikiPolicy` will be appended to the list of `permission_policies` when upgrading the environment, provided that `permission_policies` has the default value. If any non-default `permission_polices` are active, `ReadonlyWikiPolicy` **will need to be manually added** to the list. A message will be echoed to the console when upgrading the environment, indicating if any action needs to be taken.
     285
     286**!ReadonlyWikiPolicy must be listed //before// !DefaultPermissionPolicy**. The latter returns `True` to allow modify, delete or rename actions when the user has the respective `WIKI_*` permission, without consideration for the read-only attribute.
     287
     288The `ReadonlyWikiPolicy` returns `False` to deny modify, delete and rename actions on wiki pages when the page has the read-only attribute set and the user does not have `WIKI_ADMIN`, regardless of `WIKI_MODIFY`, `WIKI_DELETE` and `WIKI_RENAME` permissions. It returns `None` for all other cases.
     289
     290When active, the [#AuthzPolicy] should therefore come before `ReadonlyWikiPolicy`, allowing it to grant or deny the actions on individual resources, which is the usual ordering for `AuthzPolicy` in the `permission_policies` list.
     291{{{
     292[trac]
     293permission_policies = AuthzPolicy,
     294 ReadonlyWikiPolicy,
     295 DefaultPermissionPolicy,
     296 LegacyAttachmentPolicy
     297}}}
     298
     299The placement of [#AuthzSourcePolicy] relative to `ReadonlyWikiPolicy` does not matter since they don't perform checks on the same realms.
     300
     301For all other permission policies, the user will need to decide the proper ordering. Generally, if the permission policy should be capable of overriding the check performed by `ReadonlyWikiPolicy`, it should come before `ReadonlyWikiPolicy` in the list. If the `ReadonlyWikiPolicy` should override the check performed by another permission policy, as is the case for `DefaultPermissionPolicy`, then `ReadonlyWikiPolicy` should come first.
     302
    274303== Debugging permissions
    275304In trac.ini set:
