Changes between Version 52 and Version 53 of rdfstore
- Oct 29, 2012, 9:03:29 PM (12 years ago)
rdfstore
v52 v53 56 56 }}} 57 57 58 where the entity/subject is dataset:2d41a526-a595-4c57-a144-23ce4a922437, the attribute/predicate is title and the value/object is the literal: 'A Vegetation Map Of Tasmania'. 58 where the entity/subject is dataset:2d41a526-a595-4c57-a144-23ce4a922437, the attribute/predicate is title and the value/object is the literal: 'A Vegetation Map Of Tasmania'. Basically, the subject/entity and the value/object are 'things' and the attribute is the relationship between them. 59 59 60 RDF has an XML implementation (see http://www.w3.org/TR/rdf-syntax-grammar). This triple encoded in RDF/XML wouldlook like:60 RDF has an XML implementation (see http://www.w3.org/TR/rdf-syntax-grammar). This triple encoded in RDF/XML might look like: 61 61 62 62 {{{ … … 69 69 }}} 70 70 71 RDFS (or RDF Schema) adds a class structure to RDF triples. OWL (Web Ontology Language) adds inference rules to RDF/RDFS. 71 RDFS (or RDF Schema) adds the concept that each triplet may be a class - so we can now represent classes of 'things' and the different types of relationships between these 'things'. 72 73 OWL (Web Ontology Language) adds inference rules to RDF/RDFS. 72 74 73 75 !GeoNetwork is good at:
