Changes between Version 2 and Version 3 of proposals/readonly
- Jan 23, 2013, 1:08:55 AM (11 years ago)
proposals/readonly
v2 v3 41 41 === determining read-only status === 42 42 43 The read-only status of GeoNetwork is determined by a periodic 'DB heartbeat' that attempts to write (and delete) a value in the database. If the situation changes (i.e. GN is not read-only but fails to write, or GN is read-only but succeeds writing) the read-only status of GN is dynamically adapted. 43 The read-only status of GeoNetwork is determined by a periodic 'DB heartbeat' that attempts to write (and delete) a value in the database. If the situation changes (i.e. GN is not read-only but fails to write, or GN is read-only but succeeds writing) the read-only status of GN is dynamically adapted. The heartbeat's initial and fixed delay in seconds can be set in config.xml and have default values 5 and 60. 44 44 45 45 === other changes ===
