Changes between Version 4 and Version 5 of proposals/WFSDataDownloader
- Sep 25, 2012, 12:37:19 AM (12 years ago)
v4 v5 8 8 || '''Assigned to release''' || 2.x || 9 9 || '''Resources''' || Available || 10 || '''Ticket #''' || ||11 || '''Github source''' || https://github.com/fxprunayre/core-geonetwork/tree/feature/dow load-wfs ||10 || '''Ticket #''' || #1072 || 11 || '''Github source''' || https://github.com/fxprunayre/core-geonetwork/tree/feature/download-wfs || 12 12 13 13 … … 36 36 [[Image(geonetwork-wfs-download.png)]] 37 37 38 The area of interest could be the linked map extent or a map control added to draw the extraction area. 38 39 39 TODO:40 * Error reporting:41 * it could be nice to have some error reporting area - custom message displayed in the form which disappear after some secondes instead of modal popup)42 * Form43 * hide projection if only one define (we can't get server side supported projection ?)44 * hide service version with parameter (to make form simple) - an advanced/simple download form ?45 * format : use radio instead of combo ?46 * Download area:47 * download area is the coordinates input or a map (if attached to the widget) extent. A rectangle could be better.48 * if coordinates are update, the map is not49 * IE support50 40 51 41 === Proposal Type ===
