Changes between Version 1 and Version 2 of proposals/WFSDataDownloader
- Sep 17, 2012, 7:07:57 AM (12 years ago)
v1 v2 15 15 16 16 17 == Overview == 17 == Proposal == 18 19 The WFS data downloader component is a simple widget which helps user downloading data from a WFS service. A form is displayed in order to select: 20 * a service (usually referenced in a metadata record) 21 * a layer (aka. feature type) (which may be referenced in a metadata record) 22 * an output format 23 * a projection 24 * an area of interest (a bounding box) 25 26 The service and layer can be use to initialize the component. 27 28 If the service is not available, a warning is displayed. 29 If the layer is not published in the service, a warning is displayed. 30 31 A "download data" button is added to the view mode of the metadata when a WFS is registered in the current record. 18 32 19 33 34 TODO: 35 * Error reporting: 36 * it could be nice to have some error reporting area - custom message displayed in the form which disappear after some secondes instead of modal popup) 37 * Form 38 * hide projection if only one define (we can't get server side supported projection ?) 39 * hide service version with parameter (to make form simple) - an advanced/simple download form ? 40 * format : use radio instead of combo ? 41 * Download area: 42 * download area is the coordinates input or a map (if attached to the widget) extent. A rectangle could be better. 43 * if coordinates are update, the map is not 44 * IE support 45 20 46 === Proposal Type === 21 * '''Type''': Discoverability47 * '''Type''': Widget 22 48 * '''App''': !GeoNetwork 23 * '''Module''': Metadata and search services 24 25 === Links === 26 27 49 * '''Module''': Client app 28 50 29 51 === Voting history === … … 32 54 * ? 33 55 34 == Proposal ==35 36 37 56 == Risks == 57 * None. 38 58 39 59 == Participants ==
