108 | | * Root element : |
109 | | * how-to manage same types ? eg. gmd:pointOfContact, gmd:contact, gmd:citedResponsibleParty, gmd:distributorContact elements are all gmd:CI_ResponsibleParty. Root element is not enough to be able to decide where a sub-template could be inserted. For the contact gmd:CI_ResponsibleParty would be a better type identifier. |
110 | | * qualifiedName in the root column : maybe namespace is better ? |
111 | | * When adding a contact as sub-template, editor want to set his role (which could be different according to the record) ? How to set this as a parameter to the sub-template ? |
112 | | * should we use metadata import page to import sub template ? or a custom one ? |
113 | | * how to autodetect schema for templates ? - maybe we need a specific import page to set schema value. or if user set subtemplate for the type, then schema is mandatory ? |
114 | | * we always edit in advanced mode - at least non flat mode to provide all schema elements ? |
115 | | * Subtemplate model |
116 | | * we need a title for all types of subtemplate (to be display in search). Where/how to configure ? |
117 | | * Quid on extent ? using description which is not mandatory ? |
118 | | * deleting a subtemplate and lost XLinks - how to manage ? |
| 108 | * Model |
| 109 | * Root element : |
| 110 | * how-to manage same types ? eg. gmd:pointOfContact, gmd:contact, gmd:citedResponsibleParty, gmd:distributorContact elements are all gmd:CI_ResponsibleParty. Root element is not enough to be able to decide where a sub-template could be inserted. For the contact gmd:CI_ResponsibleParty would be a better type identifier. |
| 111 | * qualifiedName in the root column : maybe namespace is better ? |
| 112 | * Search |
| 113 | * Index |
| 114 | * do we need more than full text indexing ? |
| 115 | * BriefFormat : defined in metadata-iso19139 using a subtemplate XSL mode |
| 116 | * for extent, how to define a title ? using description which is not mandatory ? |
| 117 | * Editor |
| 118 | * When adding a contact as sub-template, editor want to set his role (which could be different according to the record) ? How to set this as a parameter to the sub-template ? |
| 119 | * Manage |
| 120 | * should we use metadata import page to import sub template ? or a custom one ? |
| 121 | * how to autodetect schema for templates ? - maybe we need a specific import page to set schema value. or if user set subtemplate for the type, then schema is mandatory ? |
| 122 | * deleting a subtemplate and lost XLinks - how to manage ? |
