Changes between Version 1 and Version 2 of proposals/DocumentAndFieldBoosting
- Dec 20, 2011, 2:27:10 AM (13 years ago)
v1 v2 13 13 The main objective of this proposal is to be able to customize default Lucene scoring in order to promote certain types of records. 14 14 15 A common use case could be: to promote series and not promote datasets part of a series (the relation navigation will drive user from series to children). 16 15 A common use case could be to promote series and not promote datasets part of a series (the relation navigation will drive user from series to children). 16 For example, having a catalogue with : 17 * urban atlas (series) 18 * urban atlas for Paris (dataset) 19 * urban atlas for London (dataset) 20 * other records (which may contains urban atlas in other fields like abstract). 21 while searching for "urban atlas", the order of the results will depends on the content of each records. With this proposal, catalogue administrator will be able to give rules to promote series and records not part of a series for example. Then the results will be : 22 1. urban atlas (series) 23 1. other records (which may contains urban atlas in abstract). 24 1. urban atlas for Paris (dataset) 25 1. urban atlas for London (dataset) 17 26 18 27 === Proposal Type === 19 28 * '''Type''': Core Change 20 29 * '''App''': !GeoNetwork 21 * '''Module''': LuceneConfig30 * '''Module''': !LuceneConfig 22 31 23 32 === Links === … … 33 42 == Proposal == 34 43 35 Document and field boosting are applied at index time . See boosting query to do boosting at search time (see#336).44 Document and field boosting are applied at index time (See boosting query to do boosting at search time in #336). 36 45 37 Add the capability to set field and document boosting as explained in ticket #708. 46 See ticket #708 for configuration and patch. 47 48 This feature has to be used by expert users to alter default search behavior scoring according to catalogue content. It needs tuning and experimentation to not promote too much some records. 38 49 39 50
