Changes between Version 2 and Version 3 of metadatachanges
- Jan 8, 2012, 7:22:47 AM (12 years ago)
metadatachanges
v2 v3 51 51 The first approach is the easiest to code particularly as regards maintaining consistency between the subversion repository and the database: if the database commit fails we can simply avoid committing any changes to the subversion repository. If any of the subversion repository commits fail, then we can abort the database commit as well. However, excepting the simplest operations on a single record and without some possibly substantial changes to the existing code, the changes recorded in the subversion repository will bare little or no resemblance to the changes that are made by !GeoNetwork services. For example, if the user decides to change the privileges on a metadata record, this would result in more than one commit to the subversion repository (in fact the number of commits would be equal to the number of group permissions selected in the privilege interface). 52 52 53 The second approach is more difficult to code: subversion changes need to be bundled by keeping the subversion commit editor open and using a listener to commit/abort the changes to the subversion repository when the database is committed/aborted. This scenario is further complicated by the design of the tmatesoft api which does not allow reentrant calls on a subversion repository object and the fact that the editor cannot open files and directories in the repository more than [[once http://osdir.com/ml/version-control.subversion.javasvn.user/2007-10/msg00053.html]]53 The second approach is more difficult to code: subversion changes need to be bundled by keeping the subversion commit editor open and using a listener to commit/abort the changes to the subversion repository when the database is committed/aborted. This scenario is further complicated by the design of the tmatesoft api which does not allow reentrant calls on a subversion repository object and the fact that the editor cannot open files and directories in the repository more than once as described at http://osdir.com/ml/version-control.subversion.javasvn.user/2007-10/msg00053.html. 54 54 55 55
