52 | | The first approach is the easiest to code particularly as regards maintaining consistency between the subversion repository and the database: if the database ops fails we can simply avoid committing any changes to the subversion repository. If any of the subversion repository commits fail, then we can abort the database commit as well (it's not quite as simple as this actually!!!). However, excepting the simplest operations on a single record, the changes recorded in the subversion repository will bare little or no resemblance to the changes that are made by !GeoNetwork services. For example, if the user decides to change the privileges on a metadata record, this would result in more than one commit to the subversion repository (in fact the number of commits would be equal to the number of group permissions selected in the privilege interface as they are set one by one in the DataManager). |
| 52 | The first approach is the easiest to code particularly as regards maintaining consistency between the subversion repository and the database: if the database ops fails we can simply avoid committing any changes to the subversion repository. If any of the subversion repository commits fail, then we can abort the database commit as well (it's not quite as simple as this actually!!!). However, excepting the simplest operations on a single record, the changes recorded in the subversion repository will bare little or no resemblance to the changes that are made by !GeoNetwork services. For example, if the user decides to change the privileges on a metadata record, this would result in more than one commit to the subversion repository (in fact the number of commits would be equal to the number of group permissions selected in the privilege interface as they are set one by one in the !DataManager). |
