Changes between Version 11 and Version 12 of ebXMLObjectModel
- Jul 21, 2008, 8:50:53 AM (16 years ago)
ebXMLObjectModel
v11 v12 44 44 In order to efficiently create an XML binding, that is to say the ability to marshal and unmarshal XML documents, the Java Beans implementation is decorated with a [http://jibx.sourceforge.net/ JiXB binding]. JiXB was chosen over other binding frameworks such as [http://xmlbeans.apache.org/ XMLBeans], [http://www.castor.org/ Castor] and [https://jaxb.dev.java.net/ JAXB] because of its [https://bindmark.dev.java.net/old-index.html high performance], ease of use, and non-intrusive programming model. 45 45 46 The core of the binding is an XML definition that relates XML elements to Java Beans. A simple snippet from the binding is the following, which relates a LocalizedString from the ebXML XSD to its Java Bean representation: 47 48 {{{ 49 50 <mapping name="LocalizedString" class="org.geonetwork.ebxml.informationmodel.core.datatype.LocalizedString" > 51 <value style="attribute" name="lang" field="lang" usage="optional"/> 52 <value style="attribute" name="value" field="value" usage="optional" /> 53 <value style="attribute" name="charset" field="charset" usage="optional" /> 54 </mapping> 55 56 }}} 57 46 58 A sample of code that marshals a !RegistryObject document is the following. This and similar code you can find in the Object Model's unit test suite. 47 59
