Changes between Version 2 and Version 3 of crawler
- 05/29/07 02:50:15 (18 years ago)
TabularUnified crawler
v2 v3 8 8 Description: 9 9 A deamon process that automatically generates metadata for spatial data resources. The application is required to crawl a directory structure and extract data properties and other auxiliary metadata. It will write an ISO19115/19139 compliant metadata record. 10 The application will be able to synchronize with a catalog application to retrieve metadata that was updated through the web interface (for example) in !GeoNetwork opensource.10 The application will be able to synchronize data, metadata and basic privileges with a catalog application. Eventually it will also be able to provide the required information to deploy !OGC web map services of different flavors (WMS, WCS, WFS) including e.g. symbology files (SLD). 11 11 12 12 Requirements:
