Changes between Version 12 and Version 13 of agenda
- Apr 2, 2009, 7:23:09 AM (15 years ago)
agenda
v12 v13 1 1 2 == Running the geonetwork-axis2-gen-ebrim/generate.bat to generate skeleton webservice code == 2 (1) Running the geonetwork-axis2-gen-ebrim/generate.bat to generate skeleton webservice code 3 3 * While running the Axis generation of skeleton code for '''OGCWebServicePort''', this message is given: 4 4 '' No mapping defined for element {http://www.opengis.net/cat/wrs/1.0}Capabilities'' … … 7 7 ''No mapping defined for element {http://www.opengis.net/cat/csw/2.0.2}Harvest'' 8 8 9 Question: Heikki, what is the status of the binding? I have forgotten the latest details. You would finish the binding? 9 10 11 12 (2) About the TeamEngine : 13 - I have created a new project in SVN named geonetwork-teamengine-ebrim 14 - My maven tests do not work, Team Engine is not Maven compliant. I have discussed this with Simone and they will make the TeamEngine Maven compliant (I am saying Maven compliant but I could as well say portable, it is not about Maven) 15 - When running locally our app, you can run this batch file: /geonetwork-teamengine-ebrim/TEAMEngine2/geonetworkTE.bat 16 This will fail because our implementation is not yet linked.
