Changes between Version 8 and Version 9 of XPATH
- Apr 17, 2009, 2:46:17 AM (15 years ago)
XPATH
v8 v9 8 8 ---- 9 9 10 == = Introduction ===10 == Introduction == 11 11 12 12 XPATH is a language to precisely select a set of nodes in an XML document. It is also sometimes used to address certain parts of Java object graphs. One of the requirements for the ebRIM project is to support XPATH queries in OGC Filters. 13 13 14 14 15 == = Issue: XPATH on Lucene ===15 == Issue: XPATH on Lucene == 16 16 17 17 It would be straightforward to evaluate XPATH against complete ebRIM documents (domain object graphs). However, we do not have all ebRIM data in memory, therefore we cannot simply evaluate XPATH queries against complete ebRIM documents. This suggests that the best option is to evaluate XPATH queries against the Lucene index. How should we go about doing that ? … … 28 28 }}} 29 29 30 I'm currently looking into their sources to learn more about their implementation, specifical y [http://dev.alfresco.com/resource/docs/java/repository/org/alfresco/util/SearchLanguageConversion.html org.alfresco.util.SearchLanguageConversion].30 I'm currently looking into their sources to learn more about their implementation, specifically [http://dev.alfresco.com/resource/docs/java/repository/org/alfresco/util/SearchLanguageConversion.html org.alfresco.util.SearchLanguageConversion]. 31 31 32 32 An exchange on the [http://www.mail-archive.com/solr-user@lucene.apache.org/msg07186.html Solr mailing list] point in the same direction (i.e. storing XPATH info in the Lucene index). 33 33 34 34 Then there's [http://acs.lbl.gov/nux/ Nux], which also seems to support XPATH on Lucene: "Arbitrary Lucene fulltext queries can be run from Java or from XQuery/XPath/XSLT via a simple extension function." I have no clue yet how they do it, but I'm taking a peek at their source very soon. 35 36 === Storing XPATH information in the index vs. mapping XPATH queries directly to structured Lucene queries === 37 38 Erik and me have started a highly polemical debate about which is a better approach, storing XPATH info in Lucene or mapping XPATH queries to more structured Lucene queries. 39 {{{ 40 Stored XPATH approach 41 42 * use an extra field in the Lucene index to store XPATH information 43 * the information stored at index time could be a !LocationPath to the object being indexed, which could be matched at search time to XPATH queries 44 * Erik thinks this approach would 'pollute' our domain driven development model, as there is no intrinsic justification for this extra index field in our domain. 45 * Heikki thinks that that doesn't matter, because the structure of a Lucene index is inherently not domain-driven (for example there are 46 fields that are repeated TOKENIZED and NON-TOKENIZED to allow for both full text search and ordering of results). 47 }}} 48 {{{ 49 Structured Lucene query approach 50 51 * use Lucene queries that refer to properties of the queried object using the dot notation 52 * example : !ExtrinsicObject.classificationList.Classification.id=someClassificationId 53 * this would obviate the need for an extra field in the index 54 * it is not known whether such Lucene queries actually work, in our index structure. Jose ? 55 }}} 56 We should decide on this matter very soon. 35 57 36 58 … … 39 61 40 62 41
