Changes between Version 2 and Version 3 of TracWiki
04/22/15 15:15:37 (10 years ago)
  • TabularUnified TracWiki
    v2 v3
    1 = The Trac Wiki Engine =
     1= The Trac Wiki System =
    22[[TracGuideToc]]
    4 Trac has a built-in wiki engine, used for text and documentation throughout the system. WikiFormatting is used in [wiki:TitleIndex wiki pages], [wiki:TracTickets tickets] and [wiki:TracChangeset check-in log messages].  This allows for formatted text and hyperlinks in and between all Trac modules.
     4Trac has a built-in wiki system which you can use for organizing knowledge and information in a very flexible way by [WikiNewPage creating pages] containing an intuitive and easy to learn textual markup. This text markup is also used in all other parts of the system, not only in [wiki:TitleIndex wiki pages], but also in [wiki:TracTickets ticket] description and comments, [wiki:TracChangeset check-in log messages], [wiki:TracRoadmap milestone] descriptions and [wiki:TracReports report] descriptions, even in third-party extensions.
     5It allows for formatted text and hyperlinks in and between all Trac modules.
    56
    6 Editing wiki text is easy, using any web browser and a simple [WikiFormatting formatting system], rather than more complex markup languages like HTML.  The reasoning behind its design is that HTML, with its large collection of nestable tags, is too complicated to allow fast-paced editing, and distracts from the actual content of the pages. Note though that Trac also supports [wiki:WikiHtml HTML], [wiki:WikiRestructuredText reStructuredText] and [http://www.textism.com/tools/textile/ Textile] as alternative markup formats.
     7Editing wiki text is easy, using any web browser and a simple [WikiFormatting formatting system], rather than more complex markup languages like HTML.  The reasoning behind its design is that HTML, with its large collection of nestable tags, is too complicated to allow fast-paced editing, and distracts from the actual content of the pages. Note though that Trac also supports [WikiHtml HTML], [WikiRestructuredText reStructuredText] and [http://www.textism.com/tools/textile/ Textile] as alternative markup formats, which can eventually be used in parts of a page (so called wiki “blocks”).
    78
    8 The main goal of the wiki is to make editing text easier and ''encourage'' people to contribute and annotate text content for a project.
     9The main goal of the wiki is to make editing text easier and ''encourage'' people to contribute and annotate text content for a project. Trac also provides a simple toolbar to make formatting text even easier, and supports the [http://universaleditbutton.org/Universal_Edit_Button universal edit button] of your browser.
    910
    10 The wiki itself does not enforce any structure, but rather resembles a stack of empty sheets of paper, where you can organize information and documentation as you see fit, and later reorganize if necessary.
     11The wiki itself does not enforce any structure, but rather resembles a stack of empty sheets of paper, where you can organize information and documentation as you see fit, and later reorganize if necessary.
     12As contributing to a wiki is essentially building hypertext,
     13general advice regarding HTML authoring apply here as well.
     14For example, the ''[http://www.w3.org/Provider/Style Style Guide for online hypertext]'' explains how to think about the
     15[http://www.w3.org/Provider/Style/Structure.html overall structure of a work]
     16and how to organize information [http://www.w3.org/Provider/Style/WithinDocument.html within each document]. One of the most important tips is “make your HTML page such that you can read it even if you don't follow any links.”
    1117
    12 For more help on editing wiki text, see these pages:
    13  * WikiFormatting
    14  * WikiPageNames
    15  * WikiNewPage
    16  * TracLinks
    17  * WikiMacros
    18  * WikiProcessors
    19  * PageTemplates
     18Learn more about:
     19 * WikiFormatting rules, including advanced topics like WikiMacros and WikiProcessors
     20 * How to use WikiPageNames and other forms of TracLinks which are used to refer in a precise way to any resource within Trac
    2021
    21 If you want to practice editing, please use the SandBox.
     22If you want to practice editing, please use the SandBox. Note that not all Trac wikis are editable by anyone, this depends on the local policy; check with your Trac administrators.
    2223
    23 Some more information about wiki on the web:
    24  * http://wikipedia.org/wiki/Wiki
    25  * http://c2.com/cgi/wiki?WikiHistory
    26  * http://www.usemod.com/cgi-bin/mb.pl?WhyWikiWorks
     24Before saving your changes, you can ''Preview'' the page or ''Review the Changes'' you've made.
     25You can get an automatic preview of the formatting as you type when you activate the ''Edit Side-by-side'' mode (you have to Preview the page for the setting to take effect). '' There is a [wiki:/TracIni#trac-section configurable delay] between when you make your edit and when the automatic preview will update.''
     27Some more information about wikis on the web:
     28 * A definition of [http://wikipedia.org/wiki/Wiki Wiki], in a famous wiki encyclopedia
     29 * The [http://c2.com/cgi/wiki?WikiHistory History] of the original wiki
     30 * A wiki page explaining [http://www.usemod.com/cgi-bin/mb.pl?WhyWikiWorks why wiki works]
    2731
    2832----
